Replacement key querie?
Foxmeister Aug 15, 2009
  1. Foxmeister
    Foxmeister Fired Up!
    1,785
    Wheres best to try for this type of key? Or can you use newer type of keys for the B5? Also, i assume it needs coding, who does this appart from Audi?
    Key still works but alarm buttons need to be pressed hard to get them to work now. Cheers.
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    whats your central locking pump part number?
    and what year is your car?
  3. Foxmeister
    1,785
    Car is a 97 on a P. Will have to get back to you on the central locking pump no. need to have a look. Do you do replacements?
  4. olds_kool
    1,094
    15
    just trying to work out if you can use a flip key as a replacement as ive never seen that type for sale new/uncut
    if your pump p/n starts 8L0 then flip key remote part should work but immo transponder (chip) was changed around 97 if you have a seperate immo box then youd probably need a new chip for the key part as these are use once only, if you have the immo built into cluster you should be able to reuse chip in a used key
  5. Foxmeister
    1,785
    Thanks for info mate, will get a look at the number, hopefully shed some light!
