Replacement Headlight globes
gareth_oau
Perth, Australia
Ive got the pre-fecelift 2000 S3
The lowbeam are xenon, but it has normal high beams, and to be honest, they arent much cop!!
I was curious on 2 things:
1/ What highbeam globe would you recommend to give more light and greater distance (that arent expensive)
2/ how easy is it to instal these globes? any instructions anywhere?
If you don't know what you're doing it can be very difficult as you have to take the whole headlight assembly apart, which includes heating it up in an oven to loosen the sealant.
The best projectors (globes) out there are the Honda S2000's, but pretty much any projector will be better than the crappy ones in the S3. Look on hidplanet.com for info on how to retrofit projectors.
thanks golf, that does seem a bit more involved than i was looking to go. i was thinking more along the lines of upping a relatively standard globe of around 55W to 80W, but otherwise OEM
I
914
imported_Tariq
I
26
