Replacement Buttons/Swiches
Madmike34 Oct 13, 2011
  1. Madmike34
    Madmike34 New Member
    9
    Previous owner had kids and they have picked at the window buttons, removed all the black stuff to leave scaby white buttons , same on the head unit numbers 1 2 3 4 5 6 , black picked off to leave a scaby white button.
    Can you get replacements, if so where and how easy to fit ?
    Cheers Mike
  2. Mike B
    Mike B Well-Known Member
    1,101
    40
    This happens any as general wear and tear.Replacement is awkward and expensive if you have to buy the complete unit.I have tried cleaning and covering with black marker
  3. haytch75
    haytch75 Member
    176
    17
    Black marker worked for me, depends how bad it is, and whether you're happy with a non show-car finish!
  4. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    window buttons = i may be able to help you out there mate, back ones? front ones?
    radio = new face if you can find one on ebay?
  5. Turkster
    2,797
    47
  6. Madmike34
    9
    cheers mate , might try the felt tip pen job out see how it turns out
  7. Turkster
    2,797
    47
    lol, the felt tip job don't pan out to well as there are lights behind them and will look messy upon light up,
  8. scottshere
    scottshere Member
    369
    On a similar topic,
    Can you replace the buttons on the aircon unit or is it a full unit change?
    Ive had the same as mike, button pickers
  9. hades-
    9,481
    646
    you can replace them if you can find any
  10. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Aircon unit, like radio, you can swap over the button facia from a doner. I stripped both mine down do stop sticky buttons after the last owner spilt fizzy pop down the controls. I have a climate module somewhere around I'm putting in eBay soon if you need a doner.
  11. Turkster
    2,797
    47
    Do the swap over. You will notic the difference. Otherwise you may as well drive a fiat around.
  12. scottshere
    scottshere Member
    369
    How much would you want for it ?
    Only need the minus button :)
  13. Scott_
    Scott_ New Member
    29
    Sorry to hijack thread but can you get the light switch surround anywhere aswell??
  14. leigh258
    leigh258 New Member
    25
    I have the same problem, havent managed to find any replacements at a resonable price, so on my passenger window switch i used a fine paint brush and painted them black... not the best finish but better than a white block! I've also read somewhere that you can take out the aircon buttons individually and spray them if you wanted to do that, just a case of masking symbols up to allow the red light to pass through.
    i did try taking off the passenger door card to remove the window switch but after attempting to remove it for 30 minutes and only managing to remove the screws i swiftly gave up with that idea.
  15. quattrojames
    14,050
    574
  16. Cabbyfan
    840
    34
    It's a single din one I think without heated seat controls part code 8e0 820 043 AJ and it's 5pr soul black. I don't know what it's worth but it's from a b7 I think.
  17. scottshere
    scottshere Member
    369
    Ok, i believe that it will be ok as i only want it as a donor for the button as mine is in excellent condition apart from 1 button
    The picker has also ruined the door panel that holds the 2 window switches gggrrrrrrr
    No idea where i can get one of those....
    Why do people sit and pick at these is beyond me (kids i can understand doing it)
  18. leigh258
    leigh258 New Member
    25
  19. jayorme
    jayorme Member
    37
    My 2002 Audi A4 1.8T failed its MOT a few weeks back because the previous owner has painted the headlamp switch after the original paint had started to strip away.. Apparently its a failure as you cant see the fog light controls?!
    Cost me £76 from Audi to replace :-(
  20. Mike B
    1,101
    40
    Why is this if fog lights are not obligatory or is it the rear which is
  21. leigh258
    leigh258 New Member
    25
    Rear fogs are obligatory, front are optional but most newer cars have them on now anyways.
