Replacement Brake Discs and Pads
tompearson Dec 6, 2009
  1. tompearson
    tompearson It's all in bits
    219
    The brakes on my S3 lack stopping power even though it is only a few thousand miles since I had new pads and discs (OEM) and the brake fluid was replaced just a few weeks ago. I think they have always had limited effect, especially compared to some other cars I have driven - the pedal never really seems to bite and feels quite spongy even after new pads and discs. I haven't found anything on here that sounds like a cause of this, given that pads, discs and fluid are all relatively new, other than the brakes are just a bit pants to start with - but if anyone has any other ideas, please let me know.
    Anyway, rather than spend a fortune on a big brake conversion (as much as I'd like to) I was looking at changing the discs and pads. I see the black diamond discs and ferrodo pads come up a lot and was looking for a good price for them when I came across this deal on ebay, am I missing something or is this a good price for some reasonably good kit?
  2. S3KO4
    S3KO4 Member
    850
    I am in similar situation with very little money. I got eBay discs and pads and after 2k it started to wobble and feels faded, I will get Zimmerman and ferodo pads but the price of the pads are a bit high! I think around £80 and discs £90ish from GS.
  3. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,269
    2,090
    I have mintex on the rears so cannot really comment on their braking ability,I have Ferodo ds2500 pads for my Brembo set up and they cost 120 delivered...just waiting for pads to wear out (after twenty odd k)
  4. <tuffty/>
    21,950
    4,227
    Black Diamond discs or EBC Ultimax if you are thinking of upgrading but I ran DS2500's on std discs with Motul RBF660 brake fluid and they were brilliant. If you discs don't need replacing yet and you are on a budget then just change the pads to DS2500's.
    Don't bother with anything else, DS2500's all the way...
  5. badger5
    9,633
    2,070
    consider DS3000's on the heavier S3's if you use your brakes hard
  6. tompearson
    219
    Cheers for the info.
    The only firm prices I have found so far for the DS2500s are in the region of 160 for fronts and 80 for rears which seem somewhat steep. Other than that I only seem to be able to find the DS Performance pads!
    Any recommendations on where to buy?
  7. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    the man above your last post does them ;)
  8. <tuffty/>
    21,950
    4,227
    Don't need to buy ferodo's for the rear, Pagid or A N Other decent normal pad is fine... S3 is over braked at the rear, all the effort is required for the front as she is a lardy little car :)
    £160 sounds about right atm as the price of these have shot up recently. Bill used to do them cheaper than this but got a shock when the last lot he got in shot up in price with no warning.
    <tuffty
  9. tompearson
    219
    Can I just check that fcp590h is the correct part for a 99 S3. If so Camskills appear to do them for 146 delivered. I'll look for something cheaper for the rears.
    I'd be interested to hear your price Bill if you are still doing them as you are based just up the road - although I'm worried I'll end up asking you about that nice ap set up you sorted for tuffty and blow my budget intentions.
    Thanks.
  10. Gops
    3,198
    666
  11. jdas03
    jdas03 Member
    603
    I got ebc turbo discs and yellow stuff pads for the front, fair bit cheaper than ds2500s. I cant compare the two as i havent tried ds2500s, all i can tell you is when discs and pads are stone cold they at least equal the stopping power of oem setup and the wamer they get the better.
    My experience vs standard pads and discs is not only on the road. On the track i met another s3 with standard pads and discs brand new on, mine were the same except ebc turbo and yellow stuff, and the difference was amazing. standard after around 10 minutes suffered bad brake fade and had to go into the pits for cool off, mine kept going! in a whole day i did not experience any brake fade. if anything they got better as i went! this is doing generally 20-30 minutes a time!
    So in conclusion ebc is a good route to go if you cant afford £150 for pads!
  12. badger5
    9,633
    2,070
    i can compare yellows to ds ferodo's - ebc suk
    ds2500 consistently good cold and hot as are ds3000
    ebc's yellows will eat disks
    fcp590h-ds2500's are £135+vat currently for info
  13. S3KO4
    S3KO4 Member
    850
    what price could you do them for?
  14. LiveWire
    LiveWire S3X
    329
    I think they are selling for that much, you will have to ask badger if that includes postage. :beerchug:
  15. S3 HODGE
    S3 HODGE Brown passenger seat.
    1,200
    Hmm....If so id be interested as my pads havent got the longest of life left.
  16. badger5
    9,633
    2,070
    is that not clear enough for you?
    as posted
  17. badger5
    9,633
    2,070
    it does'nt no
  18. crunchie
    crunchie Active Member
    880
    77
    DS2500 pads worth every penny. aint managed to crack my brembo x-drilled discs yet either, i must be getting old! then again, an S3 on the edge is a scary place to be! miss my scoob :(
