replaceing coolant temp sensor????
dplovin Oct 11, 2012
  1. dplovin
    dplovin Member
    416
    right ive got the old one out and the new one in place without the wire and clip in place yet.
    its in place now but doesnt feel very stable at all ? does it need to be right in or does it clip in place.
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    engine?
    clip holds it in place but it should push home and feel sturdy
  3. dplovin
    dplovin Member
    416
    1.8t engine mate i must just need to give it abit more force or is there a certain way it goes in
  4. stu_m
    1,440
    Im not sure on the 1.8t as mine is a TDI but on mine you have to give it a good old shove then attach the clip
  5. dplovin
    dplovin Member
    416
    think ive sussed it derrrr!!! clip pusshes in around the housing and not the sensor itself, thing is ive gone a bust the clip now Grrrrrrr!!
  6. dplovin
    dplovin Member
    416
    Temp sensor replaced but still coming up with the fault code??? Thermostat stuck open next option?? Maybe water pump ???
  7. quattrojames
    14,050
    575
    What fault code is it giving you?
  8. dplovin
    dplovin Member
    416
    17698 buddy
  9. pauldazzle
    pauldazzle Well-Known Member
    1,132
    81
    Did you put a genuine VAG CTS in?
  10. pauldazzle
    1,132
    81
  11. dplovin
    dplovin Member
    416
    That will be my problem then I've replaced the top one. Are the sensors both different or the same???
    Yeah proper vag cts
    Cheers mate
  12. pauldazzle
    1,132
    81
    Different, the lower sensor is a 2 pin.
