replaced bulb and now brake lights stuck on !?
stu_b Nov 25, 2011
  1. stu_b
    stu_b Member
    59
    just replaced a blown bulb went round the back to check all was well and realised now the brake lights appear to be permanently illuminated ? Any ideas chaps??
  2. kite
    kite Member VCDS Map User
    677
    broken brake light switch...
  3. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Had the same issue when I bought some cheap bulbs. Think the ones you need are P21W.
  4. stu_b
    stu_b Member
    59
    did a brake light switch about 6 months ago broken again already??
    maz would that cause the circuit to connect when not needed? your S3 looks the ******** by the way :salute:
  5. Maz
    1,002
    10
    Thanks Stu.
    All I know is when I fitted cheap rear bulbs recently my front and rear lights started to go nuts and those bulbs sorted it.
  6. stu_b
    stu_b Member
    59
    ok cool will try tomorrow cant be ***** with another brake light switch pain in the ***** getting the right one 4th time lucky last time!!!
  7. jcs356
    jcs356 Brum brum
    2,734
    70
    I had this on my old Ibiza, not sure if the S3 has the same bulbs but worth a check. Anyway, the bulbs in the Ibiza had double filaments - one filament runs the normal tail lights; the other (brighter) filament runs the brake lights. There should, in theory, only be one way of fitting the bulb into the holder so that everything works hunky-dory.
    Anyway, I managed to get my Ibiza bulb in the wrong way (i.e. by 180 degrees) and the net result was the brake light filament was permanently lit rather than the sidelight. Sorted by spinning the bulb back round through 180 degrees.
  8. stu_b
    stu_b Member
    59
    JCS you little dancer! just saved me a weekend of cocking about with brake switches and bulbs! who'd have though you could put a bulb in the wrong way round?!
  9. jcs356
    jcs356 Brum brum
    2,734
    70
    I'm guessing that worked then!
    Yeah, I was perplexed when I did it on my Ibiza. And in theory you shouldn't be able to put it in the wrong way around, but I guess brute force + ignorance can make anything fit!
