Replaced Audi Concert with Sony MEX-BT2700
taffjohn Oct 8, 2013
  1. taffjohn
    taffjohn New Member
    27
    Hi All,
    Recently replaced my Audi Concert with Sony MEX-BT2700 and must say very impressed, only problem
    I have is intermitent signal with FM (Depends how you hold aerial and no MW).
    I've recently purchased a PC5-52 Aerial adaptor, would this improve my signal for both MW/FM & where do i connect blue lead?
    Any advice or pics would be most welcome.
  2. AK47UK
    AK47UK Active Member
    450
    34
    The blue lead should be for the power antenna, it may power the aerial amplifier. If your headunit has a PANT (or power antenna) wire then connect to this, if not you could connect to a remote wire so the wire will be fed power when your ignition is on. Don't connect to a perm live cable or else it will be on all the time even when the car is parked.
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    blue lead is for amplifier remote lead it is a switched 12v live ... only live output is when headunit is on
    blue with white stripe is power antennae ... is a switched ignition live
    blue lead is only applicable if you want to turn on external amplifiers remotely
