Replace the carpet?
davesimmo Apr 12, 2014
  1. davesimmo
    davesimmo Member
    180
    13
    Is it possible to replace the carpet or is it a job not worth doing.
    there is a slight hole in the carpet near the pedals where a previous owner has driven without floor mats and worn the carpet out.
    i have mats in place and you can't see it, but I know it's there and it bugs me.
    just wondered if anyone on here has gone to the trouble of replacing their carpet and how much does a replacement cost, is it worth it?
  2. NHN
    29,596
    1,782
    Ignore it, the cost & time to swap all bits out isn't worth a small hole :)
    davesimmo likes this.
  3. davesimmo
    davesimmo Member
    180
    13
    Ok fair enough. Just me been picky. :beee:
  4. NHN
    29,596
    1,782
    No you're not, its reality of the cost factor tbh mate, I would feel the same as you.
  5. manor13
    manor13 Active Member
    726
    110
    43
    on an old orion I cut square from a scrap car and then cut same size hole in floor lifted and stuck under carpet onto sound deadening if you looked very hard you could see it but I was happy with it. i had seen it on a valeting course when they fix fag burns.
  6. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,046
    790
    A new carpet is going to set you back around £500 for Audi + fitting unless you can do the job yourself. I would do what has been suggested above find a local company that could repair the damage. There are a few areas of carpet which hidden behind trim that could be cut out to repair the damage, seen that done with seats before and its give an all most perfect result.
