Replace Rear Wiper Blade - How?
Lapchien66 Jan 23, 2010
  1. Lapchien66
    Lapchien66 New Member
    27
    Can anyone describe how to replace the rear wiper blade? Seems pretty tight and if I pull any harder I'm sure I'll bust something...
  2. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Anyone?
  3. clem2192
    clem2192 Member
    174
    As far as I am aware its just a pull out jobbie. If you're worried about busting anything why not remove the rear wiper from the car to give you a bit better leaverage?
    Hope this helps!
  4. mike foster
    3,967
    There are two retaining clips in the centre of the blade. These need releasing with a screwdriver and then the blade just pulls off. When installing the new blade make sure that there is an audible 'click' which indicates the new blade is fastened in place properly. Good luck !
