Replace Bonnet Lever (footwell)
Jamie1985 Jul 1, 2013
  1. Jamie1985
    Jamie1985 Member
    67
    Hi all have been away from the site for a while car has been garaged for a fair time,
    Anyways got it out today to service before using fluids, oil etc and the bonnet release lever in the drivers footwell snapped, ive managed to get the bonnet open by removing front bumper!!!
    My question is how hard is it to replace the lever inside the footwell and also would i have to just do that or would i have to replace the whole cable and the latch under the bonnet?
    Regards
    Jamie
  2. madmike01uk
    madmike01uk Member
    430
    21
    Very easy just replace the latch.
  3. Jamie1985
    Jamie1985 Member
    67
    Is it as easy as that does it clip on or is it screwed together?
    Away from home at the moment so cant look :unsure:
  4. madmike01uk
    madmike01uk Member
    430
    21
    Just remove the lower trim panel the it unscrews out. You need a torx bit to remove the lever.
  5. Dubbers1
    Dubbers1 Top Gear VCDS Map User
    270
    67
    I had to replace mine when i got my car, its a bit fiddly but not a difficult job
  6. dope
    dope alcoholic pervert
    199
    Just reviving this, with an extra question: can it be changed while the bonnet is stuck shut? Or does the bonnet need to be opened by some other means?
  7. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    You should be able to change it fine as the is no tension on the cable until it is pulled
  8. dope
    199
    Thanks man
