Repairing underseal
Vertigo1 Jan 21, 2008
  1. Vertigo1
    Vertigo1 Well-Known Member
    3,477
    632
    Anyone got any tips for repairing underseal, or know what the best stuff to use is?
    Managed to scrape a bit of it off under one of the sills at the weekend, down to the metal so needs covering up again really. (it's a long story which involves a field, a lot of mud, the RAC and a man with a land rover).
  2. marms
    marms Member
    833
  3. SteveTDCi
    SteveTDCi Active Member
    1,407
    I'd just clean up the area and then apply some stone chip. Its all I used on the underside of my escort. I got the stuff from my local motor factors / paint specialist. Most of the stuff you buy contains waxoil. I then painted mine.
  4. Vertigo1
    3,477
    632
    I'm not exactly sure what the stuff that's been scraped off is tbh. I presumed it was underseal but someone has suggested otherwise. It's like a thick rubbery material which is obviously applied to protect the underside of the car from grit and stones etc, then painted over.
    Any idea exactly what it is?
  5. SteveTDCi
    1,407
    It will be some form of rubberised underseal, you should be able to pick something up locally, it doesn't need to be the exact stuff as applied by the factory.
  6. a3guy
    a3guy Member
    206
    used to use this stuff yonks ago
    Tetraschutz
  7. SteveTDCi
    1,407
    Thats ok but it leaves a crackled finish if you brush it on
  8. Vertigo1
    3,477
    632
    There seems to be some confusion between underseal and "stonechip paint", is it the latter which I need (and what that schutz stuff is - someone else mentioned this name)?
    Steve, well the underside of the sills does have a kind of crinkly finish - do you reckon I'd be better off masking the area and spraying rather than brushing?
  9. SteveTDCi
    1,407
    depends what finish you want, brushing is easier. The spray stuff doesn't go that far, I never masked when I did the escort. You could try Audi - they might have something.
