Removing transfer box
shabba168 Nov 22, 2011
  1. shabba168
    shabba168 Member
    49
    Got a new flywheel and clutch for the car. When I drop the box out to do it do I need to remove the transfer box.
    If I do can it be done with out the special tool
  2. <tuffty/>
    21,958
    4,229
    Needs the tool to undo the bolt in the middle of the drive flange (drivers side)... essentially a really long allen key... this needs to be removed to allow you to remove the bevel box...
    Looks like this...
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Or make your own....6mm i think it is...
    I would not have thought you would need to split it as it all slides past the engine...just, but it will be heavy
  4. <tuffty/>
    21,958
    4,229
    It does slide to a point but its an ****... it catches the end of the block so you have to jostle it past... not that easy to do when the thing weighs so much... Was bad enough with 2 people and a lift ramp...
    As Dave says, its 6mm and you could make one from a long 6mm or some steel tube/bar with a bit of 6mm allen key welded on the end maybe... either way its easier to get the box off and back on again with the bevel box removed...
  5. shabba168
    shabba168 Member
    49
    How bigs the hole it needs to go down so I can get a nice bar and allen key I have a 5 inch 6mm allen key dunno if it's long enough
  6. s3dave
    10,110
    736
    the hole is about 20mm in diameter and it needs to be a good 12" long
  7. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    78
    Lmao is it just my dirty mind?
  8. s3dave
    10,110
    736
    you filthy brute....:)
    sakib likes this.
  9. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    any idea where that tool can be gotten from?
  10. Kave
    Kave Member
    160
    I got my box out leaving the transfer box in place. Was a PITA to refit the box again, but can be done with a lot of swearing. Makes taking the gearbox out easier.
    The tool can be had at the dealers for around £9. Its VAG tool 1669.
    Good luck.
  11. Nathan Barnes
    Nathan Barnes Active Member
    153
    46
