Removing the drivers side air vent...
S3 Paul Jun 14, 2009
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    Ive Bought a air vent gauge pod for my AFR guage...
    I bought the full vent kit from awesome GTI but my problem now is how the vent comes out. The new one shows no bolts or clips... all i can see are 4 things that look like they may hold the pipework to the vent... I realy need to know how to get the bloodything out !
    Anybody else taken it out for any reason i would be greatfull if you could tell me how.
  2. wibble111
    wibble111 needs to scratch the itch
    841
    IIRC you may need to remove the fuse box to get to the back of the vent.
  3. S3 Paul
    2,823
    107
    I have removed the lower dash trim and fuse box. Still can not work out how it is removed. I realy dont want to start breaking anything or marking trim that is seen.
  4. Boro&Beth
    Boro&Beth Member
    172
    Never knew those existed!
    Did you buy the whole pod or just the insert?
  5. S3 Paul
    2,823
    107
    Full vent replacement. its from awesome gti.
    Looks factory to be honest. but god knows how the standard one comes out !
  6. Broken Byzan
    13,237
    465
    If its anthing like An A4, its pushed in. Can you not tell how its fitted from the vent you have?
  7. S3 Paul
    2,823
    107
    From the new vent it does look like it pushes in then the clips on it will hold it in but... im unsure if it clips to the ducting or the dash, I darent just pull and pull till something gives.
  8. <tuffty/>
    20,904
    3,713
    If you have a face lift, you need to disconnect the wires to the illuminated vent dial, then it should (with gentle assistance) prise out from the front... it is very tight so use a large flat screwdriver with someting wrapped around the end so as not to mark any thing.
    I had this fun and games when I did my boost gauge however I stealthed mine behind the grille :)
  9. S£
    S£ Member
    683
    I done mine by removing the slats and getting my hand in there to pull it, but as tuffty said be careful with the wires to the illuminated vent dial.
  10. ianysm
    ianysm Active Member
    1,002
    They look brilliant. I quite fancy the Liquid though as it does alot of what the vagcom does (obviously not quite as detailed!) and fits nicely in place. Very tempted
  11. Dani_B19
    9,113
    346
    Whats this illuminated vent dial you lot are on about?
  12. S3 Paul
    2,823
    107
    The wheel that controls how open or closed the vent is... the white marks light up red like the dash clocks and switchs
  13. HTC
    HTC Active Member
    3,428
    9
    The factory tool for removing the vents is just a hook. It can be fashioned easily and make the task a breeze.
    Homemade tool
    To use, insert through the vent and hook it at the rear near the top, bottom or sides and pull. You can make a pair of hooks to make things easier if required.
  14. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    I've got a load of old bike wheel spokes if anyone wants any!.
  15. Dani_B19
    9,113
    346
    Im no sure if mine actualy lights up!
  16. ianysm
    1,002
    Pre facelift don't light up do they?
    Also check your dash dimmer isn't too low!
  17. S3 Paul
    2,823
    107
    HTC... your a star.
    I will be trying this in the morning.
  18. audia38l1
    audia38l1 New Member
    24
    Thanks for this posting. I am going to do the same to remove the vent as there are so many sponge debris blowing off from inside the vent and making the interior really dirty. I am not sure if this scenario happens to you all and if so, how do you guys deal with that?
