Removing the battery??!!
TerryTibbs Dec 5, 2007
  1. TerryTibbs
    TerryTibbs New Member
    ANy tips for getting that fuse box off of the top of the battery to allow removal?
    have undon the clips to allow me in to undo the 10mm nut from the terminal - but cannot work out for the life of me to remove the fuse box to get it out!
    Manual was as useful as a chocolate teapot...
    cheers
  2. Lovegroover
    Lovegroover Member
    155
    The hinge at the front of the fuse box needs to be 'unclipped' by pulling the fuse box toward the screen and away from under the hooks.... HTH
  3. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    If it's tha same as my old A3, there two push clips either side on the cover, then the cover hinges upwards and the battery can be removed (once you unbolt the steel plate holding it down)
  4. TerryTibbs
    cheers buddy - sorted it out with that
    wierd system, removed the fuse tray, then the housing at the back, THEN the clip over the battery before it came out!!
  5. jojo
    28,846
    3,509
    Changing car battery in Audi S3, 30 minutes, changing car battery in Mk2 Golf, 5 minutes...
