removing silver dash trim
tonya4 Aug 13, 2010
  1. tonya4
    tonya4 TDi Powerrrr
    408
    hi,how do you remove the 2 silver bits of trim off the dashboard?and also the ones on the doorcards?the car is a 2001 b5 facelift.
    thanks
    tony
  2. Oranoco
    Oranoco Well-Known Member
    3,974
    405
    Door cards need to come off, peel back soundproofing and work clips off carefully.
    Dash is a bitch to do, glovebox, drivers knee bolster handbrake and centre console all need to be removed and then it's cack handed to remove the push clips.
  3. NineNails
    NineNails Proud sponsor of the snack food industry
    593
    Don't try to pry the clips off, you risk snapping the plastic pins they are pushed on to. It's easiest to use an unscrewing action and the same to replace. Mind yer fingers the clips can be sharp!
  4. NineNails
    593
    Out of interst, what are you doing with the trim? I could do with a couple of bits to replace some dented ones on mine...
  5. tonya4
    tonya4 TDi Powerrrr
    408
    thanks for the replies.I'm going to be covering them with 3m di noc carbon film,I have done the gearstick surround already.
    tony
