I did mine on the floor and it was great fun!
Right the way I did it is as follows
Oil 4 downpipe bolts up with WD the day before
Engine heated right up (easy to remove the lambda's if there a little tough)
Remove air filter to get access to bolts on cat
Remove both lambda sensors
Leave to cool if you heat
Oil up bolts again
You can access 3 of the bolts from the engine bay and this is by far the easiest way to access them, I'm assuming you have a decent enough tool setup, just need a ratchet and extension bar really
Next lift the car up and get the centre section off the downpipe
Remove the heat guard at the centre of the exhaust and remove the 2 bolts holding the prop up in the centre
Mark the front of the prop with tip ex so you know where to put it back! Remove the 3 bolts with a triple square 10mm socket (I think out of memory) and move the prop over to the right
You can now access the last bolt, I used a spanner for this moving the bolt out very slowly, but I was lay on the floor when I did this
When this is out then your cat will come out pretty easy mate!
Done it last night. Car feels so much better! The low down pull is instant now and pulls a lot harder midrange top end. Def a worth while free mod
Once this has been done does the car need mapping? Or vcds to remove dash lights?
Yeah had it on a 2 poster ramp and was a lot easier. Having revo stage 2 map out on at weekend, currently stage 1 but rang revo and they said it's fine to run stage 2 with just precat delete as that's the most restrictive part of the exhaust.
how are you removing the precat is it hammer and chisel or can it be drilled out.
Like the sound of doing this, a nice stepping stone until a full system.
I had the pre-cat delete done yesterday and it's definitely a worthwhile mod, especially if you're on a budget. The turbo spools up a little quicker where the hot gasses are no longer flying out straight into a brick wall causing unnecessary back pressure, it's a little louder when giving it some as well.
I also had the GFB Diverter Valve+ fitted and this too has made a noticeable difference, the clear benefit is that it holds boost for longer. There wasn't necessarily anything wrong with the Rev G DV I had fitted in March along with my Revo Stage 1 remap and Revo CAI, however that's to be treated as a service item as where it holds boost better then the Rev D DV, it's diaphragm design means that it is prone to rupturing when driving hard in remapped cars.
All that's left now is for me to pay £60 to upgrade to my Revo software to stage 2! So I'll be arranging this with VAS Motion shortly.
Any news on how this is getting on? Think I've decided to follow suit and put funds towards some other items to get done at the same time.
It's still going great mate, I really like how the turbo spools that little bit quicker now and from 5,000rpm is where you notice that the exhaust is louder than before. For stage 2+ I'll definitely be getting a BCS Powervalve TBE but for the time being when you're on a budget, you really can't complain for what is a good cheap/free mod.
I'll be getting my stage 2 put on next month so I'll let you know how this goes as well.
Oil up bolts again
