Removing rear wiper motor/arm etc
S3IZZO May 14, 2008
  1. S3IZZO
    S3IZZO Guest
    Anyone taken the back pannel off the boot before to get to the wiper motor and rear blade?
    Just wondering how easy it was.
  2. JohnS3
    JohnS3 Active Member
    3,032
    I was told that it's 2 screws and it just pulls off. I did try it, but thought I was going to break it so left it alone. Let us know how you get on.
  3. S3IZZO
    S3IZZO Guest
    Will have a nosey around later :)
  4. Boydie
    Boydie Guest
    The boot panel is a knightmare to remove! I still havent managed to take it off :(
    Would be interested in takin the rear wiper out this summer - never use it and I hate it!
  5. h5djr
    9,465
    1,772
    Here is the workshop manual page for removing the rear lid trim.
    rear lid trim
    If you need anything more let me know.
  6. Boydie
    Boydie Guest
    thanks as usual dave - great help!
  7. S3IZZO
    S3IZZO Guest
    Cheers!!
  8. S3IZZO
    S3IZZO Guest
  9. Boydie
    Boydie Guest
    Any pictures of the finished work lad?
  10. S3IZZO
    S3IZZO Guest
    Nope, haven't fitted it yet - may be off to Club Charleys in Belgium this weekend so I need to crack on with it.
    Will post pics soon.
  11. JohnS3
    3,032
    Did the tailgate trim come off easily (and in one piece?)
  12. S3IZZO
    S3IZZO Guest
    Finally done, this was a task and a half.
    The rear trim doesn't come off easily, basicly it is a brute force job and helpful if you've got an audi specialist nearby to give you a hand (Thanks Quattronics :) ) - there's 3 clips each side, once you've taken them off with force you have to remove them as they'll be left in the boot pannel with pliers.
    The motor which connects to the arm was very hard to take apart, the fitment of the plug I bought was absolutely spot on, really happy with the end result.
  13. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
    Does removing the rear wiper permit you to park in a disabled spot?
  14. S3IZZO
    S3IZZO Guest
    It does when you own the car park; but usually, no! :asskicking:
  15. MarcQuinlivan
    2,539
    9
    If you own the car park then you should replace the wheelchair with an outline of the S3 (in white!).
  16. Boydie
    Boydie Guest
    S3IZZO - looks awesome - do you have a link to the plug piece??
  17. MarcQuinlivan
    2,539
    9
  18. S3IZZO
    S3IZZO Guest
    Yes, it's not the 30mm version, I got it with the cleaning fluid and the glue also...if you want it with that you need to select "Klebstoff+ und Reiniger" when ordering.
  19. h5djr
    9,465
    1,772
    With the rear wiper removed how to you clear the rear window when you come back to the car after it's been raining and how to you keep the rear screen clear when your driving down a motorway and it's raining.
    Personally I find the rear screen wash/wipe an essential piece of equipment, especially as I look in my rear view mirror quite a lot.
  20. MarcQuinlivan
    2,539
    9
    I'd have to agree Dave. The rear wiper is essential on any hatchback car. Although perhaps mudflaps help reduce the spray on motorways?
  21. S3IZZO
    S3IZZO Guest
    I find using the heated rear screen and regular washing helps too.
    Although I agree this is purely a form over function modification and won't be for 99.9% of people.
  22. newbiecrg
    newbiecrg windsurfer
    1,328
    I also use it a lot... maybe I should drive faster so I didn't really need it!! ahahah
    Pedro
  23. h5djr
    9,465
    1,772
    I also use RainX on the side windows and door mirrors but when I used it on the rear screen on a previous car it didn't work anywhere near as well. Also if I used the rear wiper it made a horrible noise and the blade jumped accross the screen. I've never used it on the front screen.
  24. bacardi
    bacardi Active Member
    1,139
    I had the same problem on the rear screen Dave, wiper seemed to dislike it, though I always use it on the front screen - its bloomin impressive stuff
  25. Boydie
    Boydie Guest
    I never use the rear window wiper - hate it, scratches the window and hate the smart function!
  26. MarcQuinlivan
    2,539
    9
    i believe that smart function can be disabled by VAGCOM boydie.
  27. Boydie
    Boydie Guest
    Good job marc - will look into it :)
  28. A3_3.2_S-Line
    A3_3.2_S-Line Member
    160
    Whats the smart function, I have never noticed.
  29. MarcQuinlivan
    2,539
    9
    When you have the front wipers on and put the car into reverse the rear wiper comes on automatically.
  30. t0ph0id
    t0ph0id Member
    54
    Sorry to dig out an old thread, any other tips on removing the inner boot panel?
    After removing the torx screws I've had a go at prising it off but just can't get it free.
    Anyone got any further tips?
  31. mike foster
    3,967
    There are 6 spring clips holding it on. You need to grab hold of the panel (with the boot lid up) as near to the rear screen as you can and pull very firmly downwards. It seems like you will break something but you won't. Once the first clip is off the just work your way round the lid to release them all.
    It will come off but you do need to be firm (if not almost brutal ! )
  32. t0ph0id
    t0ph0id Member
    54
    Thanks Mike
    In case anyone else finds it useful there are actually 8 spring clips, 4 on each side. I managed to get the bottom corner ones off first and then worked my way up each side.
    Knowing exactly where they are located makes it easier.
    Hopefully this will help someone else.
    My only issue now is that I cannot remove the wiper, can't free it from the motor at all. I've left it soaking in some WD40 at the moment but if anyone has any other tips I could try please let me know.
    shadow1993 likes this.
  33. TimG
    TimG Active Member
    942
    45
    Let it soak in WD at least overnight and wiggle like hell the next day. You will think it'll never come off, but suddenly it'll just pop off!
  34. t0ph0id
    t0ph0id Member
    54
    Thanks Tim, looks like I'm going to have to leave it soaking.
    I've even tried un-bolting the wiper motor and knocking the end with a hammer from the outside and it still wont budge.
    Just to confirm, once the 13mm bolt is undone it should just lift off?
  35. TimG
    TimG Active Member
    942
    45
    Yep, it should but it's never that easy! Just persist with the wd and wiggling! Trust me.
  36. TimG
    TimG Active Member
    942
    45
  37. t0ph0id
    t0ph0id Member
    54
    Not yet! It's stuck pretty solid.
    On holiday at the moment so will tackle it again when I get back.
    Any other ideas?
  38. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Drives me potty, what a stupid function
  39. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    I tried to get the rear wiper off the other day. Tried everything possible and it still wouldn't budge.
    Will have to try soaking it overnight as suggested I think.
  40. moag
    moag she's no d-turbo
    821
    35
    The bolts seize very easily, it's unlikely that soaking in WD40 will help much.
    I had issues getting mine off and ended up buying a wiper removal tool. Any local motor factors should have them, they only cost a few pounds. Alternately you could rig something up with a g-clamp
