Strange question I know...
How do you remove the rear parcel shelf in the A4? I need to give it a good clean, but because of the angle of the window etc, it's virtually impossible to get down to the very edges!
Chas
Hi Sorry it took so long but here we go
(this all is for non folding seats!!!)
1. remove head rests
2. these just pull up. (they hold realy good so give it good pull or try turn them when pulling up)
thats how they hold
3. now pull the top end forward and up (it should slide out)
these are the bottom end (holders?!)
4. now remove the sub cover carefully slide a trim removal tool (screwdriver) under front end and pull up a bit along whole front
and slide it up and pull a bit to the front
now u need undo 4 screws (red marking) holding the pascel shelf with sub.u will see them.{upsidedown pic. (my sub is gone)}
5. now you have 4 trim holders under front of the parcel shelf.slide your fingers under the parcel shelf and u should find them.
6. now place your hand on side edge of the parcel shelf and push down you should see a bit of these
they slides into holes in parcel shelf side edges
when it comes loose you can start pulling the parcel shelf forward (carefully)
just dont forget disconecct the brake light
the parcel shelf hold it self under the window (back end) with 4 flexible thingy witch slides into 4 holes
and thats it!!!
I hope it helps.
