Removing rear number plate
LandSpeed Jan 17, 2011
  1. LandSpeed
    LandSpeed Member
    229
    ive done a search but cant find any answers to my problem.
    i need to remove my rear number plate as its starting to look a little tatty, its fixed with 2 plastic screws, now when i try to undo them with a screw driver, the screw twists slightly at the top end but feels as though the bottom does not, as though its stuck. now obviously i dont want to turn the screw too much as by doing this it may just snap !
    any ideas ?
  2. allyp
    allyp Member
    222
    drill it out ?maybe
  3. quattrojames
    14,050
    574
    I'd just wind the screw till it snaps and then you can trim it off flush with the bodywork. Then stick the new plates and it avoids having to drill them.
  4. hades-
    9,481
    646
    snap it off
    and stick it back on look better than haveing screws holding it on
  5. LandSpeed
    LandSpeed Member
    229
    think i will go with snapping the screws then putting back on with them sticky pads
    thanks guys
  6. allyp
    allyp Member
    222
    make sure they are straight m8 lol
  7. LandSpeed
    LandSpeed Member
    229
    indeed i wil lol
  8. silversurfer
    silversurfer Member
    223
    try to stick a flat headed screw driver behind the number plate and pull it forward to create pressure on the screw then try to undo it.. I should come out then (Worked on the van at work :))
  9. Yappy
    Yappy A4 b6 TDI V6 Quattro Sport
    150
    Or take the inside boot cover off and hold the plastic screw housing and then undo the screw
    Or as everyone has said on here break it and stick the plate back on mate
  10. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    I can't stand screwed on number plates. 3M DS tape does the job.
