Removing rear door card
jvbates May 24, 2007
  1. jvbates
    jvbates Member
    57
    Hi Guys, I'm after some advice/help.
    Yesterday, my other half put the rear window down, whilst forgetting that it had a kid's window blind attached to it! As you can imagine it ripped the bottom sucker off and it slid down and is stuck onto the glass inside the door pocket!
    My question is... How easy is it to remove the rear door card in a B6 S4? If it's pretty easy will I be able to get to the glass or is it beind another skin?
    Also, anyone have any instructions how to do it? Failing that i'll have to drop it off at the dealers!
    Any help much appreciated!
  2. tommyt2
    tommyt2 Member
    97
    its easy to take off just screws and clips start by pulling off the interior trim from the door just pull it at the end closest to the hinges this will show you the 3 or 4 srews then there is one screw under the arm rest part of the door its deep in the door so you need a lond enough screw driver.Hope this helps.
  3. jvbates
    jvbates Member
    57
    Cheers Tommyt2, do you know if you can get to the glass after you take the door card off? I don't want to do it and find that the glass sits behind a seperate skin that you can't get to!?
  4. AndyMac
    9,832
    45
    It does sit behind a seperate skin, so pretty sure you can get to the mechanism, but not the glass. I guess there might be an access panel behind the foam cover.
