Removing parcel shelf from saloon
Oranoco May 25, 2009
  1. Oranoco
    Oranoco Well-Known Member
    3,957
    404
    How do I do it as i can't see anything obvious to aid in removing it. Want to bin off the back speakers and get some bass into the cabin
  2. joost
    joost Active Member
    1,169
    I took the rear seat backrest off as mine's not split/fold then the shelf slid forward
  3. Broken Byzan
    13,237
    465
    If you lay upside down in the boot, and look up, there are 3 push type clips you need to squeeze to remove hidden inside holes in the box section towards the seat.
    Don't forhet to release the wires fro the brake light if you have one, and you will have to feed the seat belts though after un bolting them
  4. Oranoco
    3,957
    404
    Yep success!
    The standard speakers are out and cables hidden away neatly and I fiddled with the whole audio setup and it now takes your head off. I'm a happy chap! :o.k:
    Next job is change the gear lever over in my gear linkage and wire up the facelift heater vents. Anybody know what colour they illuminate?
  5. Broken Byzan
    13,237
    465
    Red mate. Matches the dash etc a treat
  6. Oranoco
    3,957
    404
    Blinding. Finished the gear linkage and got that set up nicely, loads better.
    Just grab some lunch and i can remove the dials and glove box so I can puit the wires in. Do people just tap into the cigarette lighter illumination or is there somewhere better?
