Removing overspray on rear lights?
jojo Apr 7, 2012
  1. jojo
    29,001
    3,657
    Is there any easy way of doing this? Recently purchased a set of used facelift rear lights, I noticed the driverside one has specs of overspray on it. I've tried to use SRP and Tar remover to see if they would have any effect, but no use. I don't really want to try spirits on it for fear of damaging the surface as it's plastic.
    Anyone have any ideas? I don't have a machine polisher to hand to give that a try unfortunately.
  2. joedredd
    joedredd 2006 A6 S line 3.0tdi Quattro Avant VCDS Map User
    200
    27
    Pending size of specks, how about a razor blade gently pop them off then finish off with SRP or try some T Cut then polish off.
  3. jojo
    29,001
    3,657
    There must be 15-20 specs on close inspection, guess I will have to pick them off one by one at some point.
  4. kite
    kite Member VCDS Map User
    677
    Claybar !!
  5. CHEZ
    CHEZ moderately amusing Supporter
    4,200
    887
    claybar (bilts) or good old scraping/picking with a blade mate if only a small coverage! or even try your finger nail!
    defo dont use petrol or spirits! this will remove it, but will ****** the plastic!
  6. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    Worked a treat for my over spry on my car.
  7. shady-ninja
    shady-ninja Active Member
    999
    53
    cut the chase mate and use brake fluid.
    but try not to get on your paint work as it will strip it clear off.
  8. jojo
    29,001
    3,657
    Tried using fingernails, no chance, so I doubt a clay bar will have any effect.
    Brake fluid on a bit of cloth aye, I'll give that a bash tomorrow unless someone else has a better idea between now and then.
  9. ScottD3
    15,166
    1,126
    Same thing with mine mate.
    Finger nails was no good but the clay bar worked really well.
  10. jojo
    29,001
    3,657
    Guess it won't hurt to try.
  11. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
    some polish with a liitle cut in it maybe
  12. ScottD3
    15,166
    1,126
    Done it yet JoJo?
  13. wazz
    wazz Member
    89
    Thinners???
