Removing interior door trim...
PNH80 Mar 8, 2009
  1. PNH80
    PNH80 Low life livin' the high life.
    1,633
    Alright fellas, hope you've all had a super weekend so far!
    I'll soon be replacing my piano black door trim in the front and back of my A3 (3 door) with the aluminium trim. Just for a change and to keep it interesting. I'll be keeping the center console piano black though.
    I have the satin finish OEM alloy gearknob so aluminium on the gear surround and ashtray would be overkill IMO.
    The piano black centre console with aluminium in the doors seems to be a theme now anyway with the S5, RS6 etc so should look good.
    Anyway... Can anyone PLEASE supply a diagram of where the clips are located on the pieces of trim. Last thing i want to do is start aimlessly ramming a screwdriver behind them and snap the clips.
    Also just a bit of advice on the best way to remove them would be brilliant if possible.
    P.S.... The piano black inserts will be for sale after i've removed them if anyone's interested. I also have an S-Line perforated leather gear knob/stick & gator if anyone wants one (was only on the car for approx 6K miles so it's mint). Open to offers!
    Thanks in advance guys... Much appreciated!
    Paul.
  2. h5djr
    9,466
    1,773
  3. PNH80
    1,633
    Thanks Dave you are a prince amongst men. Those diagrams seem to be for the sportback though. The inserts are different.
    However... By the looks of it there's no science to it. Seems you just get a thin plastic tool and force them off. Famous last words!!!
  4. richs2891
    richs2891 I cant spell !
    441
  5. h5djr
    9,466
    1,773
    Yes Paul they were the 5-door version.
    Here is the one for the 3-door...
    door trim - 3 door
  6. PNH80
    1,633
    Thanks guys that's brilliant. Definitely answers my question!
    The clips for Audi interior bits are actually really robust i find, they clunk in and out nicely.
    I'll probably take some photos of the interior once it's done.
    Paul.
  7. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,514
    658
    Just pull them off at a corner carefully - no need to consult a manual
    You will have them all off within 5 mins
  8. PNH80
    1,633
    Well they all came off nice and easy in the end!
    Anyone want to buy a set of Piano black inserts??
  9. MrTea
    MrTea Member
    53
    Good to hear you succeeded and it's an easy job as I'm thinking of changing my horrible "wooden" inserts.
    Anyone know if it's just as easy to remove the insert around the base of the gear stick?
  10. sparky208
    sparky208 Member
    37
  11. MrTea
    MrTea Member
    53
    cool, thanks for that.
    Now to find some aluminum trim... :think:
    PNH80 where did you source yours from if u don't mind me asking?
    I need to do all doors (3 door), ash tray and base of gear stick.
  12. edition
    edition Active Member
    1,426
    P.m me a price for the trims as long as they are a1 cond.
    Cheers :)
  13. Khufu
    Khufu Well-Known Member
    5,704
    31
    set has just gone on ebay, they arent cheap even 2nd hand!
  14. PNH80
    1,633
    Well i was relatively lucky because i didn't want to swap the ashtray and gearstick surround. I got the 2 door inserts and trim for rear seats (3 door) off of Ebay for just over £100 (taken from a 2008 S3....Yes i did check they were legit, the guy has a breakers). Which may seem pricey BUT consider full sets are pushing £300 it's not too bad. Also i've got a set of piano black trim to sell so i'll recoup some money anyway.
    Be advised that they are like rocking horse sh*t and breakers know what they're worth so don't expect any bargains!
    Edition mate, send me a PM with an offer. I can probably get some snaps if you want. Basically they're in lightly used condition. No scratches, only surface swirling which is unavoidable. These can all be polished out with some Meg's Plast-X (think it's called that anyway!) and they'll be as new.
    Depends what you call cheap really mate. They're an unreal price from the stealers so just over £100 for all 4 doors i can live with. It's overpriced but hey, we bought Audi's so lets not start complaining now lol
  15. PNH80
    1,633
    Dave... Do you have a diagram for removing the trim on the rear panels?
    I removed the front trim yesterday very easily and stupidly assumed the rear would be the same.... Christ almighty, those things are stuck on ridgid.
    Just want to make sure the arm rest/pad doesn't have to be pulled up or anything first.
  16. kolash
    kolash Member
    46
    Dave do you still have these pics the links are broken. Would really appreciate them as I too want to remove the aluminium trim from door. Cheers!
