Removing Injectors from 2001 1.9Tdi
connaco Sep 20, 2009
  1. connaco
    connaco New Member
    One of the cylinders was misfiring on hard acceleration but it ran fine 95% of the time so kept using the car for commute and then a few weeks later one of the cylinders packed in totally. Took it into a garage and they ran a diagnostics on it and it came back that the problem was the injector on cylinder 1. Audi said they only replace all 4 injectors at £1600, I only need one!! Have managed to find one available online at £180 but i cant get the injector out! does anyone know what tool is needed to remove it?
    This is the injector that needs removing, can anyone help!?:wacko:
  2. paul20v
    paul20v Audi fanatic
    1,113
    Hi
    its probably not the injector its the injector loom which is around £40 quid
    they always if there going too give trouble do so on number 1 cylinder as the loom is unsupported here unlike the rest of the loom,
    change this first i can nearly 99% say this is your problem not the injector .
  3. BILKO1
    BILKO1 Member
    301
    I agree with Paul common fault this.
  4. technics100
    technics100 Active Member
    850
    25
    I had a misfire on one of my 1.9 TDi's, it turned out to be the injector wiring harness too, its only about £40 and an easy change, I would be doing this first and see how you get on.. better than £180 or £1600..
