Removing ignition key
Big Bird Mar 22, 2010
  1. Big Bird
    Big Bird Member
    116
    15
    Just occasionally, i seem to have trouble removing the key from the ignition lock. I have to restart the car, switch it off again and then take the key out!
    Is there some sort of system Audi requires you to do in order to remove it/ am i being daft/ or have i got a problem with my key????
  2. johnnythepie
    johnnythepie Well-Known Member
    2,242
    76
    No you dont have a problem.m on my second ignition lock, soon to be my third.Since day one ive been pissed off with shoving the damn thing in and out (ooeerrr).IIve tried evey combination but still ****.Hate it.Makes a **** getaway car.The ignition lock is about £70 if you want to do it yourself
  3. Big Bird
    Big Bird Member
    116
    15
    Did you get your's replaced under warranty, and what did Audi say about it??
  4. johnnythepie
    2,242
    76
    replaced under warranty no questions asked
  5. MattW
    MattW Finding Reverse Team Navarra
    262
    15
    Have advanced key so never had to use it, may have a fiddle to see whether it does work now!
  6. Bradders
    Bradders New Member
    25
    BB - Mines the same pain in the a*se.
  7. Big Bird
    Big Bird Member
    116
    15
    Weirdly enough, since posting this up, it's only stuck maybe once or twice!!!! Typical!!!!:tocktock:
  8. Kalashnikov
    Kalashnikov Active Member
    232
    44
    Anymore experience of these, happened to me twice in 1 month
  9. benjie
    benjie Well-Known Member
    1,223
    305
    It happened to me a few times. Since then, I wait a fraction of a second longer after the engine has stopped to pull the key out - no problem since.
  10. Kalashnikov
    232
    44
    Top stuff. How much of a fraction ?
  11. benjie
    1,223
    305
    Probably a whole second. Just like the pause you have when you're reading and there's a comma (Not a Clarkson comma, a real one!)
    Kalashnikov likes this.
  12. Kalashnikov
    232
    44
    Lol, I was only pulling your leg. But I do need to hold my horse. It's a bitchh when it happens
    benjie likes this.
  13. AdamB8
    AdamB8 Active Member TFSI Owners Group quattro Audi A4 s tronic S-line owners group
    110
    40
    I've just got a B8.. Thought there was something wrong with because I couldn't get the key to release.. I've found that if you press the key to turn the engine off and wait literally a second it'll come straight out when you pull it
  14. bonifacy87
    bonifacy87 Active Member
    265
    68
    I have my one for a year and never happened to me
  15. Anthony566
    Anthony566 Active Member
    732
    111
    43
    Had mine over a year and this has never happened ...
  16. Kalashnikov
    232
    44
    Let me confirm it happens intermittently
  17. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    3,239
    1,976
    Mine does this if I'm too keen at pulling the key out.
  18. benjie
    1,223
    305
    So basically, what we're all saying, is that you shouldn't pull out too quickly.
    Well...!
  19. razza1
    razza1 Well-Known Member
    3,077
    831
    I think you can actually hear the click when it's ready to release
  20. Kalashnikov
    232
    44
    Interesting I'll check it again. Later thx
  21. T0m
    T0m Active Member
    516
    26
    You all have an issue taking the key out I have the other issue where when I push the Key in (after Ive already put my foot on the clutch) it sometimes doesnt start the lights and ignition come on but its as if it doesnt register the clutch is pressed. Its the only thing I hate about this car my 7 year old can do it better than I can!
  22. rum4mo
    rum4mo Well-Known Member
    1,274
    273
    Maybe he has smaller feet and longer legs??!!! Seriously though, this was quoted as being an issue with the clutch release mechanism which might have been updated in some models, or worse, slave cylinder assembly or at least the switch, which yes, I think is down inside the bellhousing - nice!
  23. Luke2.0tdi2010
    Luke2.0tdi2010 Active Member
    287
    50
    I have this same problem, I've had my b8 now for just over a month and occasionally I push the key in to start it and..... nothing! I wondered if it was something I was doing wrong, now it seems like I'm not the only one! Maybe I'll try and get it looked at under warranty.
  24. T0m
    T0m Active Member
    516
    26
    I think the issue is Im putting my foot on the clutch too soon before the key is registered so it doesnt activate the swtich whereever it is as the ignition is not on when I put my foot on the clutch?!
    But saying that there have been times where I have put my foot on the clutch and then put the key in and its started think I must be heavy handed in one way or the other but will see how i get on, its going in on the 17th for some rattles so I could get them to look at it then if I feel its too much of an issue.
  25. fcuk1_6
    fcuk1_6 Member
    52
    Mine did this a few times when I first got it, lightened the load by removing extra keys from set and been totally fine since.
  26. rum4mo
    1,274
    273
    Typically, I will have the clutch pedal down to the floor before pressing the key to start - though as has been said already, I will have put the key in first.
    Really, in my experience, all my issues have been down, I hope, to me simply not pressing the clutch down fully - as this is the first car that needed me to use the clutch pedal in that way!
