Removing grab handles/ashtray?
pengjn Aug 23, 2010
  1. pengjn
    pengjn Member
    81
    I'm about to replace the ashtray with a storage tray and I think I need to remove the grab handles either side of the gear level. I can feel a couple of holes, which I guess have screws but I can't imagine that they are the only things holding them so strongly. Does anyone have instructions on how to remove the grab handles and ash tray, and ideally the tools I'll need to do the job?
    Cheers,
    Jim
  2. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    I found a thread on another site the other day but basically:
    1. Remove the gear knob surround by pulling it from the front upwards
    2. Undo 3 screws per handle, 1 is under the surround, another in the hole you've found and the other is at the front under the centre console.
  3. pengjn
    pengjn Member
    81
    Mine is a DSG - is it OK to pull hard on the gear knob surround? I gave it a bit of a tug but it seemed pretty happy in there and I didn't want to break it...
  4. Staz
    6,206
    64
    Yep pull it hard mate, it has a bit of a lip at the front, get your fingers under there and pull.
    Insert disclaimer here
  5. pengjn
    pengjn Member
    81
    Cool - it popped off nicely, thank you. I see 2 hexagonal bolts holding the grab handles, 2 torx holding in the ashtray and I know there are two in the grab handle holes but...
    i) Are the ones in the grab handle holes hexagonal bolts or torx?
    ii) I can't find the ones at the front under the centre console. Do i need to remove something else to get at them?
    iii) What sort of tool do i need to undo the hexagonal bolts? Is it a socket set or something? Sorry - i'm a totally mechanical f-wit :)
  6. Staz
    6,206
    64
    You may not be able to see the ones at the front unless you squeeze your head right into a tiny gap, they're there though, get ya fingers in!
  7. Staz
    6,206
    64
    While I was out taking another picture I took this:
  8. klik
    klik Member
    234
  9. pengjn
    pengjn Member
    81
    Thanks very much. One question, how do you do step 1 'Remove trim from around hazard light button\coin tray'?
  10. Staz
    6,206
    64
    You don't need to do that, just follow the steps I gave with the aid of the photos on the other site.
  11. pengjn
    pengjn Member
    81
    OK cool. Hopefully the tool will have arrived in the post, so i'll be able to have a crack at it tonight.
