Removing Fog Lamps and Rear lamp clusters
lgooch Aug 29, 2010
  1. lgooch
    lgooch Well-Known Member VCDS Map User
    1,140
    149
    Guys
    Is there any how to's about showing you how to remove the front fog lamps as I have a spider inside mine which has weaved a web and then died. I need to split it apart and clean it out.
    Also does anyone know how to remove the rear light cluster as the sub in the left hand panel is causing the light cluster to vibrate as i dont think its in properly.
    Cheers in advance
    Goochy
  2. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,235
    328
    not to sure on the fog light but if yours is a 3door then its very easy in the boot there is a round cover on each side of the boot take that off then with a screwdriver undo the screw then push the light unit towards the pavement / road whichever side it is then it should come off easy
  3. sub39h
    sub39h Active Member
    2,502
    yeah rear light is in the manual. front fog might be a bit more tricky...
  4. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    From what I remember with the front fog lights, you remove the plastic grille first by pulling it out and then unscrew the fog light - 3 screws.
