Removing dsg selector mechanism
Mikemc Jun 14, 2013
  1. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Hi as title, managed to brake a plastic part in my dsg selector and have sourced a replacement selector. How easy is it to remove it? I may even just be able to get to the broken part if I taken out the armrest then centre console area?
  2. NHN
    29,601
    1,782
    Were you trying to do the dsg newer gearknob mod?
    The gear unit comes out from underneath, so exhaust of, which may or may not require cat with, heat shielding etc its not the easiest job.
  3. Mikemc
    1,024
    37
    Uh oh. Doesn't sound good. It was when removing my ashtray I dropped one of the screws and thought it had gone to heaven. Found out it hadn't when I pushed the selector up :(
  4. NHN
    29,601
    1,782
    They're not exactly small bolts either, so you should be able to get it out with some double sided tape & a coat hanger.
  5. N8
    17,163
    720
    Guy who changed mine said it was the worst job in the world :laugh:
    NHN likes this.
  6. Mikemc
    1,024
    37
    I got the bolt. It's just if you have a dsg, remove the trim and you can see a bit of yellow plastic on the end of something to lock it into P
  7. NHN
    29,601
    1,782
    Huh, you broke the lock?
    Pics?
  8. Mikemc
    1,024
    37
    As you can see the yellow plastic has snapped Doh!
  9. NHN
    29,601
    1,782
    Oh feck me, I have a dsg unit I bought for research, the units cost £450 from audi, you could probably strip them down & swap part over, PM if interested I'll tell you what I paid for it.
  10. Lewbo
    Lewbo Well-Known Member
    1,279
    110
    I had to replace one a few years ago on my 1st a3 paid £300 from main dealer and wasn't that bad to Change actually, as said it comes out from underneath, drop exhaust from manifold and push the heat shield to one side this is how I did it.
