Removing clocks from A3 tdi 2.0 sport
RobMorris Sep 13, 2011
  1. RobMorris
    RobMorris Member
    539
    10
    Chaps
    Is it easy enough to remove the clocks/instrument cluster?
    How to do it?
    ...to replace a couple of bulbs..
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    I'm sure there are no replacable bulbs unless you plan to solder a new one in.
    To removed it, release the steering adjustment latch & pull the steering wheel towards you and down & lock it
    The trim under the clocks pulls out towards you & will reveal two 10mm bolts. Remove these and slide the clocks out. As you turn them to remove it you will see a multiplug on the back. It is held in with a catch that has to be rotated out of the way. As you rotate it, the multiplug should come out at the same time.
  3. RobMorris
    RobMorris Member
    539
    10
  4. NHN
    29,328
    1,708
    LED afaik.
