Removing central locking pump
Mr.Blonde May 26, 2010
  1. Mr.Blonde
    Mr.Blonde Member
    443
    Hi,my central locking pump is fooked so i need to get it out to have a look at it and part numbers etc.is there a guide on how to remove the pump and check if its ok??..
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    It's just secured with a big zip tie, but you have to take the boot panel out to get to it.
  3. Mr.Blonde
    Mr.Blonde Member
    443
    oh right.ive had a quick look and looks like i will have to remove the sub box to??..or taking the whole boot panel out i wont have to remove the sub?..
  4. finesse
    finesse Active Member
    2,805
    would like to know too
  5. landopanda
    landopanda Member
    143
    Me 3
  6. Mr.Blonde
    Mr.Blonde Member
    443
    Bump!!....someone must of taken there pump out and either tested or fixed it hmmm???.
  7. Westy
    Westy Well-Known Member
    17,443
    1,105
    Like Andy said the best way in is by moving the boot trim out the way. If you remove the screws under the boot net fixings and remove the plastic trim around the lock mech. If i remember correctly there are 2 more screws inside the cubby hole where the pump lives. You should then be able to tug very hard on the trim around the pump and it should all unclip and pull away giving you more room to move.
    What symptoms you got with the pump steve?
  8. Mr.Blonde
    Mr.Blonde Member
    443
    Well the central locking has stopped mate but i can still hear the pump working away in the boot when i open the car etc,so i reckon its the pump.Is there a way of testing the pump once i have got it out mate?
  9. finesse
    2,805
    error I got was
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    Sounds loud and runs for a while
  10. Westy
    17,443
    1,105
    The usual thing that goes is the internals shear off and leave you needing a recon kit to fix it. When you get it out open it up and see if the motor cogs have packed in. You can buy the recon kits off ebay for quite cheap. If you dont fancy doing it yourself drop "olds_kool" a PM as he does reconditioned pumps and takes yours as a replacement for about £60.
  11. finesse
    2,805
    lol how do I lock the car after I have removed it for a swap, don't have a garage :ninja:
  12. sportquattro
    sportquattro Active Member
    845
    51
    Just use the key, simples. Remote locking wont work but the locks still can be operated with the key like the old days.
  13. finesse
    2,805
    thanks sportsquattro
  14. Mr.Blonde
    Mr.Blonde Member
    443
    Yep ive just removed my pump and i will open it up and have a look later.quiet an easy job really.
  15. finesse
    2,805
    Any chance of pictures/guide?
  16. Mr.Blonde
    Mr.Blonde Member
    443
    No pics mate but a quick guide.
    1st thing i did was take out the boot floor.Then i removed three rope eyes,one to the left and the other two towards the bumper.You have to remove these two so you can take out the plastic strip which is held in by torx screws.This is the strip to the rear that goes over the boot lock.
    Remove the cover to the sub etc and if you look up inside there is a plastic black screw which has to be removed.Push down the rear seats and there should be a rubber type of screw next to the seat lock hoop if you get me.once these have been removed you just need to give it a good pull!!...then just clip the cable tie on the pump and disconect the pipes and socket.
    hope this helps,im not to good at explaning things.i should of taken some photos!.
  17. OllieH
    OllieH Member
    368
    I'm getting this aswell. Will have to take a look at some time...
  18. finesse
    2,805
    Another job for you to do Ollie :nunu:
  19. OllieH
    OllieH Member
    368
    lol, tell me about it :wacko:
