Removing bumper - help!
jrsteeve May 12, 2012
  1. jrsteeve
    jrsteeve Member
    136
    So i've spent the last hour undoing all of the torx screws etc but it's refusing to budge, seems reluctant close to the headlights on both sides, anything i've missed or any tips?
    Been following this Fourtitude.com - DIY: front bumper removal and blackout grille install (think i've just answered my own Q by looking at number 10, Ipad wasn't clear at all) but i'm not sure on part 7, where is that torx screw exactly? The one marked as D?
  2. jrsteeve
    jrsteeve Member
    136
    Right, i'm stuck on the lil plastic bits shown below (A&B), how do you remove them/which tool? So close!
  3. bluequattro
    bluequattro Member
    411
    Remove the arrowed bolt, did you remove screws underneath the bumper as well
    Cal
  4. jrsteeve
    jrsteeve Member
    136
    If you mean the bolt the arrow's pointing too that's already off, it's the rubber things labelled a and b I'm struggling with, can't see how they come away. All screws taken out underneath, it's only sticking next to the lights so am pretty sure it's just those rubbery things.
  5. Pipsqueak
    Pipsqueak Member
    137
    theres a photo further on in your link that shows you a direction to pull the bumper in. i haven't ever taken one off so don't know if thats right or not
  6. Orts
    Orts Member
    109
    The two screws inside there are torx aswell.
    from memory you get at them from the side, I used a torx allen key which was easier to get at them.
    Have you taken the wheel lining off completely? or just bending it back with your hand?
  7. jrsteeve
    jrsteeve Member
    136
    Just bent it back on both sides and undid any screws I saw underneath plus the bolt. So are the 2 rubbery screws torx? Having another go in a min.
