Removing boot lining!
Platinum70 Dec 12, 2005
  1. Platinum70
    Platinum70 Member
    194
    I have searched the site and found no info, and also tried to remove the boot lining to change a brake light bulb but I give up.
    Help, help, help please!!
  2. arthurfuxake
    1,308
    No need to remove the lining to change a light bulb. There is a small circle in the lining behind the light unit, use a flat screwdriver to prise it open and you will see a nut or a torx screw in the hole. Undo that and the light unit will hinge out from the car.
    Removing the boot lining is a bitch of a job. The rear seats have to be removed and all!
