Removing badges
dirk technic Feb 12, 2009
  1. dirk technic
    dirk technic New Member
    25
    I am thinking of removing the A4 and TDI badges, but I am worried that I will:
    a) will damage the paintwork (car is 5 years old now :crying:)
    b) leave marks
    Is there any easy way to avoid the above or should I just leave well alone? :uhm:
  2. 1210tech
    1210tech Four Ring Fanatic Team Daytona Team V6 Audi A6 Audi Avant Owner Group S-line owners group
    696
    heat up the badge with a hairdryer to warm up glue but don't over do it, keep the hairdryer moving and badge should peel off fairly easily and then use something like AutoGlym Tar & Adhesive remover on a microfibre to clean up any residue left, then polish or re-apply wax to that area
    don't use any tools like screwdrivers or wall paper scrapers, do it all by hand and you should be left with a mark free area where the badge once was :icon_thumright:
  3. dirk technic
    25
    Is it really that easy? :yahoo:
    My only other concern is that when I get the badges off that there outline will be faded into the paint work? :uhm:
  4. 1210tech
    696
    yeah there might be an outline or a darker are under the badge but a little bit of cutting polish like Menzerna PO85RD should sort that out
  5. dirk technic
    25
    Thanks for that, I had a nasty feeling you were going to say that :faint: Tried doing that once before and ended up making it look worse :(
  6. WX51TXR
    WX51TXR Polished Bliss
    1,452
    15
    If you are working by hand on Audi paint, I would suggest using Menzerna Intensive Polish applied using a Lake Country German CCS Light Pad; this will cut well enough to remove local oxidation differences (causing any fading) without leaving any nasty polishing marks. I've debadged many cars, and if you follow the advice John gave above you'll find it very straightforward. I have only ever had two unfixable problems; first on my own C2 when after taking off the badge I discovered a fixing hole beneath it (doh, had to refit the badge!), and the second on a car where the pigment layer under the clearcoat had faded, meaning the fading could not be corrected (again, the badge had to be refitted to solve the problem). :icon_thumright:
  7. dirk technic
    25
    Thanks for the help guys, the Audi badges are just stuck on aren't they? :idea: Is this safe for a novice to attempt? :wacko:
  8. WX51TXR
    1,452
    15
    Aye, every Audi we have debadged has featured stuck on badges, with no underlying fixing holes, so you should be fine. As long as you proceed with care using the above advice you'll be fine; John's advice was spot on. :icon_thumright:
