removing actuator k04
m19lte Jan 16, 2014
  1. m19lte
    m19lte Member
    123
    Evening all. I'm having boost issue's and am going to be removing my actuator. Question is how to get the actuator off ? Doe's anyone have any info or picture's ? I can't find his to remove/fit one in the searches. Thanks - 8l s3 k04-023
  2. BENJAMIN
    BENJAMIN Active Member
    503
    93
    Very easy on a ko4-02x, you have the 2 10mm nuts on the threaded bar part (remove the outer nut) and 2 10mm bolts holding the actuator bracket to the compressor housing. That's it.
    Remove the upper charge pipe and it all becomes self explanatory.
    Ko3 actuator swaps are a pita, think yourself lucky! :)
  3. m19lte
    m19lte Member
    123
    Top bloke, Cheer's Benjamin, that's the answer I was looking for :). I've got an old picture of another k04 I used have and can see the 2x10mm bolt you mean, just wasn't sure they were very accessible in situ.
  4. Gops
    3,198
    666
    I found it a little pain tbh. Take the strut brace off, TIP etc for better clearance.
  5. m19lte
    m19lte Member
    123
    cheers dude, them big tips do get in the way of pretty much everything on that side !
