Removing A4 B7 rear lights
JDM82 Mar 17, 2012
  1. JDM82
    JDM82 Member
    328
    Ive done a search but came up with nothing.
    Ive got my LED replacment lights but Im unsure how to remove the original lights.
    Has anyone got a guide on how to remove them or could some one explain. From the boot carpet to the lights, the more detail the better.
    A picture guide would be AMAZING!!!!!!!!!!!!!!!!!!!!!!!
  2. hades-
    9,482
    646
    open boot
    look on left and right side
    theres a small circle of carprt that u can pop out 10p size
    unscrew the screw behind it
    pull light then pull away from the car theres 2 pins on the wing side that pop out
    the ones in the boot lid pull carpet cut out away you wont miss it then i think its 10 or 13mm socket to remove those
    they just pull out once bolt is removed
    also tells you in the owners book
  3. hades-
    9,482
    646
  4. JDM82
    JDM82 Member
    328
    Bez your a star mate, cheers :icon_thumright:
  5. Khanage
    Khanage Member
    227
    19
    Which LED lights are they? Link?
  6. JDM82
    JDM82 Member
    328
