Removing A Pillar cover ?
richs2891 Jan 6, 2008
  1. richs2891
    richs2891 I cant spell !
    441
    I'm trying to hard wire my road angel in - I know how to wire it in to the fuse box so it switched - but how do you get the A pillar cover off & is it safe to take the cover off as the car has the blanket airgbags ?
    Richard
  2. Issac Hunt
    1,162
    You can just grab it and pull it off but if you are only wanting to route a wire then I wouldnt even bother. Just push the wire in behind the trim using something like a credit card.
  3. richs2891
    441
    Cheers - Think will have to remove the whole A Pillar cover as trying to get the RA lead to the bottom right of the windscreen !
    Richard
  4. marms
    marms Member
    833
    Yes - Just pull the A-pillar trim off a little way. Then you need to slide the trim up toward the roof to completely remove it.
    Be careful if you are running cables at you need to ensure that they are well out of the way of the curtain airbag.
  5. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    Dave R (otherwise known as H5DJR) might be able to give to the workshop guide for removing this.
  6. marms
    marms Member
    833
    Not quite sure why you'd need a diagram? All the info is above.
  7. Von Maximo
    Von Maximo The Damned
    344
    This should help you
  8. richs2891
    441
    Ah now that is good !!! very impressed !!
    Where did you get those pics from ?
    Richard
  9. h5djr
    9,420
    1,746
  10. MarcQuinlivan
    2,539
  11. Issac Hunt
    1,162
    Ebay!
  12. h5djr
    9,420
    1,746
    I have sent you a PM with details.
