Removig inside of doors
Fluid36 May 16, 2007
  1. Fluid36
    Fluid36 New Member
    Hi
    I know you need to remove the inside of the doors to get to the front speakers and replace them. I have removed the two screws (one back and one front) and now need to know if you simply wrench the door insides off or is there some trick to it. They seem stuck on pretty tight.
  2. Randomjim
    Randomjim Active Member
    2,752
    There two more screws in the door handle. Then lift it up and out over the door pin.
  3. NineNails
    NineNails Proud sponsor of the snack food industry
    591
    Hope this helps. Be careful and patient! Tricky bit is getting it back on and getting the door pin back through the hole lol
    Good Luck
    Si.
  4. shineydave
    shineydave Member
    920
    and make sure all the rubber buffers are in the slots where the hooks on the door panel locate
  5. AndyMac
    9,832
    45
    Als make sure you wind the windows down before you start.
  6. NineNails
    591
  7. easytease
    easytease cheesypeas
    433
    remember the sound deadening ;)
  8. Fluid36
    Fluid36 New Member
    Thanks to everyone who replied, all very helpfull :icon_thumright:
    I will check it out tonight, I do remember looking in the door handle for screws and not seeing any (as previous cars I've had have screws there) but maybe I was just blind.
  9. AndyMac
    9,832
    45
    There's just one up inside the cuff, remove this and push the plastic cuff down to reveal the main 2 screws.
