Remove & spray entire front grill & chrome surround?
BradHatton Sep 24, 2012
  1. BradHatton
    BradHatton Member
    394
    13
    Hi all, I've searched and had no luck.
    I have sprayed my front grill but had to mask the entire area which took the p**********, so I'm wondering whether there is a way to easily remove the grill or just the chrome surround? As I've realised the chrome surround on the lower grill pops out!
    Please let me know if you can help me out, cheers :)
  2. BradHatton
    BradHatton Member
    394
    13
    Also de-wipering tomorrow, it's a 25mm bung I need, right?
  3. kanecullen89
    kanecullen89 Active Member
    569
    160
    43
    I was wondering this. I'd like to change the chrome to black but unfortunately do not have any money spare to buy one. Am definitely considering removing and spraying. It's just a case of preparing the chrome so that the paint sticks to it and selecting a long lasting paint.
    I used to be a paint sprayer so I'm sure I could get a good finish on it. When you do it, post pics please :)
  4. BradHatton
    BradHatton Member
    394
    13
    Well I've already done it, I used U-POL primer and halfords matt black, the paint didn't fancy sticking to the grill at first so I added layer upon layer and kept sanding it back.
    It needs a couple more layers of primer then a couple layers of black and it will be done!
    Ill get pictures up soon.
  5. roblr
    roblr Member
    40
    Quite a few people use plasti-dip, very easy to apply and has a great finish, this is the only photo I've got of mine
    And yeah a 25mm bung is the right size, just make sure you block of the fluid pipe!
  6. BradHatton
    BradHatton Member
    394
    13
    How did you remove the surrounds? Thanks
  7. roblr
    roblr Member
    40
    Well I have a split grill model I'm pretty sure same applies for the single grill as well though, it pops out with clips all the way around, it's very easy to break these though so be careful! I used a small flathead and gently popped each one out
  8. garuf
    garuf Member
    130
    Might have to give this a try.
  9. BradHatton
    BradHatton Member
    394
    13
    Not sure whether i should give it a go, or just mask it all up again.. :think:
  10. Jack_tdi
    Jack_tdi Member
    287
    12
    iv got some pdf of an exploded diagram pm your email and ill send you them
    youll have to take the bumper off and you can split them into 3 seperate bits (the rings pop out too)
    dont be afraid to use a bit of force
  11. Sidhu88
    Sidhu88 Active Member
    808
    76
    If ur planning to take the grill out id warm up the clips with a hairdryer to make them a little more flexy. Should help a little
  12. phil76
    phil76 Active Member
    572
    40
    I dont know if its as easy on the single grille,when i had mine wrapped on the old car it was definately safer with the bumper off so i could get to the back of the pegs where they clip through the bumper and i wouldnt have fancied doing it another way from how much of a pain in the ass it was then,i already had the bumper off for painting at that point so it was the best way for me though
  13. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,646
    534
    take front bumper off then remove grille and clips so middle section and chrome surround come off without braking clips.
    did it myself.
    here is pic of my a3 with complete grill and surround done in gloss black. also did lower middle lip in carbon wrap.
    Before
    http://s163.photobucket.com/albums/t288/ruairi83/My%20Car/?action=view&current=DSC01256.jpg
    After
    http://m163.photobucket.com/albumview/albums/ruairi83/My Car/DSC01278-1.jpg
    http://m163.photobucket.com/albumview/albums/ruairi83/My Car/DSC01280.jpg
  14. bollyer
    bollyer New Member
