Remove side indicators?
BradHatton Nov 10, 2012
  1. BradHatton
    BradHatton Member
    394
    13
    Hi all, I want to take my indicators off to tint them, how do I remove them?
    A3 8P
  2. mike foster
    3,967
    Depends which way they have been put in but one end has a spring clip and the other end has a couple of plastic slots.
    Get your fingernails behind one end and whilst pulling towards the front of the car gently ease the 'fingernail' end outwards.
    If that doesn't work then do the fingernail trick from the other end pulling towards the rear of the car.
  3. BradHatton
    BradHatton Member
    394
    13
    Thanks! Does this pull simply off?
  4. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Try warming up the plastic a little in case it's brittle in this cold weather
  5. mike foster
    3,967
    Yes, just pulls out together with the cable. You can then remove bulb and cable and do what you like with the plastic bit !
  6. BradHatton
    BradHatton Member
    394
    13
    Thanks lads I've done it :)
  7. Oranoco
    Oranoco Well-Known Member
    3,991
    407
    Wouldn't bother tinting them though as it always looks a bit naf and you can usually sort proper smoked ones.
    Edditted. If these are the mirror mounted jobbied you seem a bit stuffed for options actually
  8. BradHatton
    BradHatton Member
    394
    13
    They're not the mirror jobbies and its only a light smoke tint so nothing tacky.
  9. mike foster
    3,967
    If they are the same as the ones I bought years ago then you can hardly see them working because they do not have reflectors in them !
