remote start
chrisa4quat Apr 26, 2011
  1. chrisa4quat
    chrisa4quat Active Member
    970
    29
    Has anyone done this and if so HOW???????????????????
  2. hades-
    9,482
    646
    quite easy
    BUT you will need to take a chip out of your spare key so the remote start works
    but that will allow a thief to snap and cap the car and nice it as it will start
  3. razza1
    razza1 Well-Known Member
    3,075
    829
    normally linked into an alarm (generally aftermarket) which does it, some also do a turbo timer on it (i.e. runs the engine at idle for a set amount of time after the drive to cool the turbo and allow excess oil to drain from it). To be honest if you drive gently for last section of your drive its not needed...
  4. chrisa4quat
    970
    29
    i do like the idea of a turbo timer, how do i do the remote start aspect? i don't want all the aftermarket alarm etc?
  5. hades-
    9,482
    646
    if you go with a T timer you cant lock the doors till the car shuts off
    you will have to use the key to lock it
  6. chrisa4quat
    970
    29
    thats ****! How do i do the remote start Bez?
  7. hades-
    9,482
    646
    best way is to get a bike remote start
    get your spare key if you have 1
    remove the transponder and tape it to a wire in the steering cowling
    bike ones are better as its not an alarm aswell
  8. hades-
    9,482
    646
  9. gjwell
    gjwell Member
    82
    I thought the point of the turbo timer was to allow the turbo to spin down without being starved of oil, as the oil pump is driven from a running engine. Probably not relevant to this thread just checking my understanding ;)
  10. hades-
    9,482
    646
    you dont need them on the audi as its got an afterrun for the turbo
  11. razza1
    3,075
    829
    Not sure to be honest, thought it had something to do with not letting oil solidify in the turbo, so I could be speaking ****....
  12. Fahim
    Fahim Member
    278
    Your both in fact quite right,
    The turbo timer will keep the engine on after you remove the ignition for a set period of time to prevent the oil from 'coking' (the destructive distillation of the engine oil)
    It allows the turbines to cool down correctly.
    Good if your thrashing it everywhere and don't have a minute to stop and wait, but its more a show-off thing than anything thing else. Not needed on diesels to be honest, if at all on petrol road driven vehicles.
  13. razza1
    3,075
    829
    Had one on the supra, didn't use it much to be honest as a pain...what's an after run?
  14. Fahim
    Fahim Member
    278
    I believe an 'After run' is an electric oil pump that once you've switched your engine off, it continues to pump oil through to the turbo to cool it down to a predetermined temperature to ensure longevity of the turbo without having the need to leave the engine running etc...
    correct me if im wrong.
  15. razza1
    3,075
    829
    Impressed if they do have that...
