Remote problem
roston100 Jun 19, 2011
  1. roston100
    roston100 Member
    370
    I changed the battery on my remote last week but since I did that the buttons wont work and I have to manually lock and unlock the car.
    I have access to Vag Com - can I use this to reprogramme the key fob? Or will I need to take it to Audi?
  2. Ads
    Ads License to drive
    8,230
    607
    Might be a silly question but have you tried another battery? Maybe the new battery you've put in your key is faulty/dead.
    Probably worth ruling that out first of all.
  3. roston100
    roston100 Member
    370
    yeah tried that! no luck :-(
  4. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,117
    1,956
  5. roston100
    roston100 Member
    370
    Thanks voorhoes - much appreciated!
  6. voorhees
    16,117
    1,956
    "Voorhoes" :lmfao:
  7. roston100
    roston100 Member
    370
    tried that but still no luck. hmmmmmm
  8. roston100
    roston100 Member
    370
    lol just saw that - my bad!!
  9. roston100
    roston100 Member
    370
    still no luck. Tried all the methods listed above and nothing happens. Looks like ill have to take it to audi :-(
  10. vw754
    vw754 vorsprung Durch Technik
    2,321
    58
    ring me il see if i can help.........check p.m
  11. NHN
    29,284
    1,695
    If you have access to a genuine vcds, give ross-tech a shout who will advise the process, no need to goto audi at all.
    TBH doing a search online will advise how this is done, its noted in a few forums.
  12. razza1
    razza1 Well-Known Member
    3,042
    803
    just tried this, as changed my battery and the remote didn't work. Got in the car pressed open and lock buttons one after the other, then put the key in and turned the engine on, pressed the buttons again for luck, and now all works :)
  13. roston100
    roston100 Member
    370
    razza - tried all that and spoke to people from vagcom today but still no luck. next step is to test whether the remotes are working or not!
