Remote locking trouble
A4tdi02 Jun 30, 2013
  1. A4tdi02
    A4tdi02 New Member
    So I am having some trouble with my car it is a 02 Audi A4 tdi, trouble is when I bought it the earth wire the goes from door wiring into the car was broke, so fixed that by soldering it, everything works fine accept when the passenger door is open it shows on the cluster display as the drivers door is open. When the drivers door is open nothing happens no display, no interior light nothing.
    The remote's 2 which are coded and have good batteries wont unlock the car or lock the car have to open the car manually with the key in the door then open the other 3 doors by the door lock switch on the drivers door.
    I have scanded with vcds and got the following codes
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Control Module Part Number: 8E0 959 433 AJ
    Component and/or Version: Komfortgerát T9F 0619
    Software Coding: 06730
    Work Shop Code: WSC 00000
    Additional Info: 8E2959802B Tõrsteuer.FS BRM 4.11
    Additional Info: 8E2959801B Tõrsteuer.BF BRM 4.11
    VCID: 79F39C4063C24D6
    12 Faults Found:
    01336 - Data Bus for Comfort System
    80-00 - Single-Wire Operation
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    01561 - Left Rear Door
    59-10 - Can't Unlock - Intermittent
    61-00 - Won't De-Safe
    01562 - Right Rear Door
    59-00 - Can't Unlock
    00956 - Key 2
    35-00 - -
    01331 - Door Control Module; Driver Side (J386)
    80-10 - Single-Wire Operation - Intermittent
    01705 - Selection Switch for Mirror-Adjust (E48)
    27-10 - Implausible Signal - Intermittent
    01559 - Drivers Door
    37-00 - Faulty
    01332 - Door Control Module; Passenger Side (J387)
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Control Module Part Number: 8E0 614 517
    Component and/or Version: ABS/ESP front 1726
    Software Coding: 04255
    Work Shop Code: WSC 06435
    VCID: E5CB40307F7A596
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    Can anyone shed some light on this, do I have faulty door latch?
    I also checked the passenger side floor for dampness and it is dry no broken wires either
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    check the rest of the wiring it sounds like you still have a break somewhere
    also pull the plug and check the pins
  3. A4tdi02
    A4tdi02 New Member
    I have checked for continuity in all the wiring in the door all seems good, and pins seem good also I will get electrical contact spray tomorrow and clean and recheck.
    Is it possible to be the door lock itself?
    thanks
  4. hades-
    9,481
    646
    sometimes the continuity check is ok
    but there can still be a break still
