Remote Locking bleep - How to add ?
Red-Eye Jun 2, 2011
  1. Red-Eye
    Red-Eye Member
    50
    Hi I'm looking for some help for a simple person !! I want to be able to change the remote locking on my car (Audi A3 8P - '57 Plate) to include a bleep when locked, this will save me going back & checking each time :-(
    I've got a cable (off ebay, I Know !!) it all talks to the car correctly but still unable to activate the bleep. Is there any where I can find simple instructions for a simple person, or can somebody please describe how to do it correctly :-/
  2. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Go to the central locking module and select coding.
    The 'soft. coding' figure in the box needs to be increased by 1024 for beep locks, and another 32 for auto-locks at 15MPH.(i.e. if your figure is 14000, you change it to 15024 for beep, 15056 for beep and auto-lock)
    I don't think the e-bay lead will access the coding block, although I may be wrong.
    Make a note of the 'soft. coding' number when you access the module, so you can go back if it goes wrong
    stewd, fitzdog88 and pangsterA3 like this.
  3. NHN
    29,328
    1,708
    He has an 8P, not 8L.
  4. mike foster
    3,967
    Module 46 - central convenience - Coding - Long coding helper - Byte 7 - tick bit 3 (locking confirmation (horn) via remote control.
    By a ' real ' one off NHN and it makes life so easy !!!!
  5. PAULF
    712
    66
    Oops, may be I should RTFQ!:redface:
    Although, I'll reiterate what Mike says, get onto NHN (or Ross-Tech) for a real lead!
  6. chrisfoster
    chrisfoster New Member
    I think you can visit your dealer for this and ask him to avail this function in your car, but instead you can also go to the lock smith for this. They are the professionals and and will make your problem solved.
  7. mike foster
    3,967
    Dealer will charge £50 - £60 for the priviledge.
    Lock smith will need to have VCDS (or similar) to enable it.
    Cheaper to find a forum member local to you who will do it for you.
  8. grimp
    grimp Member
    142
    14
    Does anyone know how to get a "biip" or "biip biip" on unlock, i drive A3 SB 2010 (8p3)
  9. mike foster
    3,967
    If it's the same as a 57 plate then you need a VCDS cable and then follow instructions in post #4 except tick bit 5 (or possibly different - I can't remember the actual one ) but the software will tell you !
  10. grimp
    grimp Member
    142
    14
    Thank you, i will try this later tonight :)
  11. Dana @ Ross-Tech
    Dana @ Ross-Tech Member
    That vehicle has a BCM so the tweaks here would apply:
    Audi A3/S3 & A3 Cabriolet (8P/FM) Tweaks - Ross-Tech Wiki
    The description is vague for Alarm, Locking and Coming Home > Alarm Confirmation via lights and horn because these are a combination of hardware/wiring and Coding/Adaptation. All of the common tweaks should be best documented using the current Beta release.
    Ross-Tech: VCDS: Downloads: Current Release and Manual
  12. johnmandy
    johnmandy Member
    74
    I would also like a bleep when locked, i have a full version of vcds purchased from gendan currently running release 11.11,
    Anyway i follow the vcds forum regularly, but really have problems doing anything but a scan.
    I am intresting in learning more but without lending my cable to local forum members and learning from them it just gets used for fault code scanning.
    So a big thanks to those who may help.
    I drive a 2007 a4 3.0l tdi.
    thanks johnK
    I
  13. pangsterA3
    pangsterA3 Member
    143
    Hi Paul - I stumbled across your reply which was exactly what I was looking for as I wanted to change this on my A3 8L.. I changed the soft code from: 15178 to 16202 as I didn't want the auto locks - just the beep. I've not got a beep when I arm the car.. is it also possible to get a beep/double beep when you disarm the car as well??.. :)
