remote key fob sometimes loses its memory !
white.akita Dec 6, 2011
  1. white.akita
    white.akita Active Member
    322
    30
    around once a month the remote locking on my b6 stops working, i have to open the door with the key then turn the ignition on and then it will work fine for weeks.
    since yesterday it has done it twice so i think its getting worse.
    i have 2 keys with a new battery in one of them but it makes no difference which key i use.
    anybody have a fix for this ?
  2. davsa4
    davsa4 Member
    257
    19
    no help but mine has done this twice in the last 6 months ?
  3. boya
    boya Member
    384
    Mine is starting to play up too, maybe once a month..
  4. white.akita
    322
    30
    i have read something about a broken wire in the drivers door being to blame but not in any detail.
    mine used to be around once a month until a few days ago where it happened around 3 times in 2 days ! today it has worked perfectly everytime.
  5. J45SON
    J45SON Member
    182
    if the key-fob is at fault, use the service fom the RAC which covers you for key-fob/imobilisers when you have the Reward or Premium account from Santander. no excess to pay and the fault is fixed mucho-cheapness.
    j
  6. marktdisport
    marktdisport Active Member
    1,195
    15
    mine does this once every few weeks and ive repaired my door wiring due to another issue but still the fob playes up.....new battery fitted etc
  7. white.akita
    322
    30
    anyone help us ? this seems like quite a common problem on the b6.
    its going to get worse, mine used to do it around once a month now its every other day.
  8. quattro tony
    quattro tony Member
    167
    Ive had the same probs with my a4 , was driving me mad, locked the car put key in my pocket and everytime took key out it wouldnt work and had to use key and do a manual reset in ignition which would sort it, tried new battery, door looms fine, vag com wes reporting a key signal fault, took key fob apart again and cleaned everything up and bent the battery terminals a little more to ensure good contact and its been working 100% up till now :thumbsup:
  9. Daniel97
    Daniel97 Member
    137
    Can you elaborate?
  10. marktdisport
    1,195
    15
    ive done this and mine also been 99% better
  11. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    ive been having probs recently with mine its done it a few times on the missus and about 4 times today!!
    will try the battery thing see if it works
  12. boya
    boya Member
    384
    Ok I tackled the issue of my paggered key fob today... It was a little scary but I done it.
    The fob had been playing up at least 4-5 times a day.
    Basically bought a key case off eBay..
    Swapped all the internals out of my old key (battery, circuit board, key blade, battery and immobiliser) the circuit board was a ***** to get out but got it in the end and now I have a nice new shiny key :)
    Before...
    After...
    I wish I had gone for the b7 fob now but never mind I am happy with it looking all new and working fine so far.
  13. stu_m
    1,441
    i forgot about this till now
    i bent the prongs up for the battery contacts and all has been well since
  14. marktdisport
    1,195
    15
    fitted 3 weeks ago another new battery and also cleaned and rebent the prongs to hold the battery tighter and touch wood it seems all ok again
  15. terryp
    terryp New Member
    19
    This is what I have just stated happening!
    I will clean the contacts and see if it happens again
    Terry
  16. marktdisport
    1,195
    15
    i think after time of them being dropped and stuff the force on the prongs get weaker ive bent mine a little to tighten the battery up and touch wood a few months it has not played up...
