Remote Central Locking Stopped Working!
balders77 Mar 20, 2014
  1. balders77
    balders77 New Member
    I've seen a few things on here about this but they're pretty old so wanted to re-post. i've got a 2008 A4 tdi and the remote central locking has suddenly stopped working. i thought it was the fob, but i tried the spare and that doesn't work either. also the red light does flash on the fob when pressed. i have to manually open the drivers door with the key, then push in the ignition to unlock the other doors from the inside.
    any ideas?
  2. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Fuse? comfort module error? where abouts are you maybe somebody local could help if you post in the vcds section?
  3. kanecullen89
    kanecullen89 Active Member
    569
    160
    43
    Hi. Did you manage to find what was wrong and fix it? My car has developed this exact problem yesterday
  4. kanecullen89
    569
    160
    43
  5. leegsi
    leegsi Active Member
    489
    57
    Mine turned out to be a comfort ecu under the passenger seat that was wet.
  6. kanecullen89
    569
    160
    43
    Thanks so much for the reply! Did you do a vcds scan beforehand? Did you get any errors?
  7. leegsi
    489
    57
    Not yet as I still have the problem and waiting for a mate to scan it.
    It started with the central locking intermittently not working then the windows stopped working.
  8. kanecullen89
    569
    160
    43
    I'll have to check my ccm tonight then to check its dry. I'm puzzled. My remote locking has stopped working. No other errors and cannot get keys to re sync. The fobs work to start the car no problem. I've scanned with vcds and no relevant errors. Thinking of just replacing the module but I would think it would show an error if something was wrong
  9. kanecullen89
    569
    160
    43
    Hi all.
    Just an update. I didn't get anyone reply with any answers for this issues so I assume that nobody had fixed it without main dealer help.
    I did have my car booked into a dealer to have the central convenience module flashed and keys recoded for the 23rd but I have managed to fix it myself.
    As I said earlier, I scanned my car with vcds and didn't get any relevant errors. The only error I got was a reoccurring error stating that the car had gone into power management (essentially the battery is knackered).
    This must have been what caused the keys to lose their programming to start with. The confusing thing is that with the B8 A4 and A5, the remote is automatically reprogrammed everytime the key is placed into the dash slot and the car turned on. This was not happening with mine.
    I was out of options.
    I then thought that maybe the power management knocked out the central convenience module (to save power for starting) and this had caused the unit to restart but not quite started back up correctly. Remember, vcds was showing no errors for the ccm.
    I tried looking on vcds for an option to completely restart the module but no job.
    I decided to find the ccm (which I located inside the boot, on the right hand side and is a fairly large unit with about 6 cable connectors going into it.
    I unplugged all of the connectors and left the car for 2 hours. MAKE SURE YOU DONT SHUT THE BOOT, YOU WILL GET LOCKED OUT, because the ccm controls all remote functions and all lock functions including the boot switch on the drivers door.
    I got back to the car, plugged all of the connectors back in, put my key in the dash, started the car, pulled the key out and hey presto, key fob works again!!
    So before you give up and take your car to the stealers to be reprogrammed, simply unplug the module for a couple of hours and it will be reset and should work again!
    jdp1962 likes this.
  10. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,399
    2,943
    I love it! Even with cars, the best IT solution is to switch it off and reboot, hahah!
    kanecullen89 likes this.
