remaps and normal unleaded petrol
m8arx Jan 13, 2011
  1. monkey_lewis
    monkey_lewis Reverse Gear
    198
    to be fair i agree if ur taking up much more than this the running costs of oil changes and tyres and servicing will be that high that the £2.50 a tank extra wont make a blind bit of difference....
  2. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    What's everyone opinion on the Super Unleaded stuff at super markets ie Sainsburys etc if there isn't a Shell garage near by and you desperately need a refill....?
  3. monkey_lewis
    198
    tbf i think most supermarkets fuel is pants, but it cant be too far away from the good stuff, weights and measures and all, personally i dont like using them, my fiancee gives them far too much money a week as it is, but tescos 5p a litre is well worth the momentum pit stop ;)
  4. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    I've been using sainsburys super unleaded for years, I sometimes fill up with v power but cant say i noticed any difference. My cars also standard thou so probably less likely to really see much difference between v power and other higher octane fuels.
  5. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    My car was running scarily lean and pulling 12's, completely unknown to me, if I wasn't running V-power it may very well have gone kaboom!
    V-power ftw! I got £5.50 off my last fill up with v-power, thank you v-power card!
  6. R-tech_Nick
    R-tech_Nick Member
    40
    On a well remapped BAM spec1 running a good ignition map with pull of around 4-5CF on V-power the difference between happy shopper fuel and V-power will be night and day. And mapping for V-power I can bring another map into play AIT v RPM ignition correction at low intake temp I can produce another 5-10bhp just from timing advance at the v AIT. Its harder to do this mapping with happy shopper fuel.
    Nick
  7. Nilz
    11,364
    903
    I just got my V Power voucher for £14.50!!! I was impressed with that, even the guy behind the counter in the station said wow!!
  8. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    is this thread aimed mainly at s3's or would my 1.8tq better from this i currently have the engine management light on the code comes back as too lean i have found 1 split pipe which i will change to correct this but looking through this thread would v power rearly make that much difference i always look at it at the pumps and think hmm is it worth it but looking at this yeh i think it is for and extra £2.50 you carnt go wrong.
    cheers nilz im defo getting the vpower card if you can rack cash back points up that way i spend about £200-£250 a month on fuel at the mo
  9. Westy
    Westy Well-Known Member
    17,443
    1,105
    Your VCDS error will probably be something to do with a boost leak somewhere as opposed to the fuel you put in the car but you will benefit from V power over 95 or 97 unleaded.
  10. Syvo
    1,338
    22
    yeh its a small pipe under the inlet manifold got the pipe just a pain in ass to get to
  11. richieb138
    richieb138 Member
    31
    Does Tesco momentum fall into the happy shopper category, or do you mean 95 RON? I've been using Tesco when it's convenient for ages thinking it's the good stuff... Should I be sticking to the 'oil giants'?
  12. Westy
    17,443
    1,105
    Tesco momentum is much better than 95/97 Ron fuels but I have been told by a certain tuner that he sees much better performance out of cars running shell 99 over tesco 99.
    This is a pain in the **** for me as I have to do a 20 mile round trip just to get to my nearest shell garage.
  13. richieb138
    richieb138 Member
    31
    Yeah, it is a pain in the ****, my nearest Shell is about that far too!
    Does anyone know (based on real facts and figures - not assumptions from filling their tank and 'feeling more power') whether BP Ultimate 97 is any good? is Tesco 99 better (or equivalent) to BP 97?
    BP or Tesco is about the most convenient for me and a lot of the other garages round here don't even sell premium at all.
    Cheers.
  14. Westy
    17,443
    1,105
    I have used both and did do some vcds logging a while back that showed how my ecu would retard ignition timing more on the 97 to the 99. I will probably stick with tesco 99 as it's more convenient for me too.
    Now I'm running revo software and my fueling is better than before, tesco will be just fine.
  15. richieb138
    richieb138 Member
    31
    Thanks Westle, that's what I wanted to hear!
    I've heard enough urban myths about the poor quality of supermarket fuel but always suspected that it wouldn't be in Tesco's interest to flog cheap **** labelled as premium.
  16. Westy
    17,443
    1,105
    It has to be 99 Ron to be sold as 99 Ron or that would be false advertising but I have been told that there is still a difference in quality between Tesco and Shell fuel.
    If a shell garage and a tesco garage were the same distance away i'd opt for shell every time but tesco is my closest for 99 ron so that's what I tend to use.
  17. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    95 RON makes baby jesus cry.
  18. DenCar
    DenCar Member
    404
    Hi paul, which pipe was it exactly? I just replaced one under the mani and that was a real pain.
    DC
    Edit: see below with quote.
  19. DenCar
    DenCar Member
    404
    Hi Paul. What pipe was it? I just replaced one and that was a pain to get at.
  20. Syvo
    1,338
    22
    ive not changed it yet m8 but its the only pipe that is split its directly under the inlet manifold if you look through the gaps on the inlet you can see a small pipe about 6" long it not one of the common pipes that awesome sell that need replacing under the inlet.
  21. DenCar
    DenCar Member
    404
    Yeah, mine was attached to the Y pipe that comes off the rocker cover breather pipe, this was split and so was the pipe attached to it. this pipe goes under the mani and attaches to the the right side of a T junction. It was a real pain to get to it, big hands in small gaps dont work, took me ages. Got the pipe from Audi and its now a solid Pipe not rubber.
    DC
  22. Westy
    17,443
    1,105
    You guys are talking about the breather hose thats right in the middle of the inlt mani?
    There are also 2 3mm hoses that come off of 2 small nipples on the left underneath the inlet mani. The front one goes to the DV top and the back one goes to the FPR.
