Remapping (no box) the 8V Tdi:s - what opportunities are there currently?
GreatBallsofFire Mar 26, 2014
  1. GreatBallsofFire
    GreatBallsofFire Member
    151
    Well, anyone knows anything? Nothing extreme, just some proper increase of the BHP and torque. I am preferably seeking for a external and detachable mapping unit, so that the car can be made standard when its time for service.
  2. arad85
    arad85 Well-Known Member Team V6 Audi S5 Black Edition
    856
    315
    I think you are mixing things. A remap is altering the ECU ROM to change the way the ECU manages the engine. As far as I understand, this is very difficult to do, involves removing the ECU and putting it on the bench due to anti-hacking protection on the ECU software (the only places I know of who do this are German companies that charge a lot and seem to have direct links to VAG companies) and will ALWAYS be visible as there is enough anti-hacking stuff that the change can always be detected. It may be possible to get a box that controls the remap parameters externally, but the remap is always visible as you have had to alter something on the ECU. The German companies also charge an arm and a leg for it....
    The only thing I know of that is not detectable is a box such as the DTUK box which alters the signals sent from a couple of sensors on the engine. Essentially, by fooling the ECU as to what its sensors are telling it, it gets it to add more fuel at a higher pressure into the engine giving it more power. They are easy to fit and remove (took me 5 minutes for mine) and because it is only massaging the signals from the sensors and is not intrusive into the ECU, there appears to be no way of detecting it has ever been fitted. This is not a remap.
  3. vegnomeat
    vegnomeat Member
    69
    17
    What are the pitfalls of using a "box" as opposed to a remap of the ECU. I previously had mapped a 335i from 305 bhp to 365 bhp, apart from the tremendous power increase I couldn't tell it was a remap.
    Does a "box" change, alter the same parameters as a remap does?
    regards
    Veggie
  4. h5djr
    9,464
    1,770
    I agree with what you are saying, except that the German companies like MTM and Abt make the changes by fitting a completely new reprogrammed ECU to replace the existing one which is why their solutions are expensive.
  5. h5djr
    9,464
    1,770
    Andrew (ABYSS) is probably the best person to answer that as he works for DTUK.
  6. GreatBallsofFire
    151
    Thanks for the information. Sorry if I mix things up, know little of these things. On the other hand I think I am looking for the more difficult (and probably more expensive) ECU manipulation, similar what this company offer (albeit you will not find the newest Audi engines included in this company's list): BSR - Car tuning, Chip tuning, Diesel performance, Ethanol conversion kit
    As far I as understand the boxes do change sufficient engine parameters and do provide engine HP but do not work in cooperating with existing systems on-board, eg diesel filter clean schedules, fuel consumption and service intervals and possible more. However, I might have to consider the box instead (if anything at all) if the code breaking proves to be to difficult. Or try the German company..
  7. h5djr
    9,464
    1,770
    The company you gave details of are like so many other companies in the re-mapping market. They list all the various older Audi engines but not the current models. This is because up until the latest models they could carry out the remapping the the OBD diagnostic socket on the car. This is no longer possible because Bosch, who provide the ECUs to Audi, have now built in greater security into their modules. Remapping can still be done but it involves removing the ECU from the car and using very specialist equipment to connect to the actual pins on the chip itself to change anything.
    Once this has been done it is refitted to the car but any dealer will be able to detect that this has been done as soon as they connect the car to their diagnostic equipment. If there was a problem with the engine it would not be covered by the warranty. The German companies who replace the ECU with their own give their own warranty on the engine but usually only for 2 years.
  8. arad85
    856
    315
    I stand corrected :) Thanks :)
  9. GreatBallsofFire
    151
    Hmm thanks. But Audi's engine warranties aren't that long-lasting either, are they? Anyway, I'll probably wait and see what happens. I am pretty sure there will be something more handy available with time. A lot of clever guys are probably scratching their heads as we are speaking. And due to the money to be earned I am pretty convinced someone will make it sooner or later.
    Edit: seems like Audi feels no responsibility whatsoever for all the people in the engine mapping business that will lose their income.. (not so serious remark)
  10. h5djr
    9,464
    1,770
    In the UK the whole Audi car carries a three year warranty. What is it in Sweden?
    I'm sure someone will come up with an answer but for it to be available in Germany it would need to have TuV approval and it will still invalidate any warranty. I think Audi are more concerned with their responsibility to the environment than to remappers making money from their engines.
  11. GreatBallsofFire
    151
    I have to check the engine warranty (edit: I checked: two year (or high mileage) is standard, but then most people by at least another year (or max two) as they are offered fairly reasonable prized and service plan is included), but likely same as in the UK. What's a TuV approval? Insurance issues perhaps? In Sweden the insurance companies had historically not bothered very much with remapped cars (as far as I know), its kind of an semi-legal grey zone.
    Audi is likely more concerned with their income, less so for customer who already bought heir car, and the environment (the latter which as I understand is more dependent on driving style) - if they where, they could offer mapping kits as BMW. However, I also understand Audi to some extent, they of course take every opportunity to protect their money and brand - but sometimes is more fruitful to be pragmatic. I myself likely will not dare to put in a remap (unless proven extremely good and clever [i.e. not "seen"] kit) during the warranty period.
  12. h5djr
    9,464
    1,770
    TuV is an organisation in Germany that has to approval products are safe for sale to the public. As far as cars are concerned any aftermarket item fitted to a car in Germany is only legal if it has TuV approval. Even things like different wheels etc. Each manufacturer of these items has to submit the for approval together with a list of cars that they intended for.
    Another point is that it is expected that in the near future the EU will impose another check in the annual test like the UK MOT test (starts when the car is three years old) which will not allow a car to pass if the engine has been modified in any way from the original EU Type Approval for that particular model. Now that could cause some problems, but it is all to do with making sure a car still meets the engine emission standards that it did when it was introduced.
  13. GreatBallsofFire
    151
    Thanks for the clarification. If its only comes down to emission, mapping could perhaps make it through the future tests (but best is detachable mapping of course). Shame Audi do not offer manual quattro 184, then I would have bought one of those (I know you very much is in favour for the S-tronic though ;))
  14. arad85
    856
    315
    As far as I know the ECU has been out 18 months so far and not been cracked. I wouldn't base a decision on buy/not buy of a tuning box believing it will be available any time soon.
    That's because we are lazy :)
  15. h5djr
    9,464
    1,770
    Speak for yourself - I like the s-tronic because it's the best form of 'manual' gear change offered on the A3 :)
  16. GreatBallsofFire
    151
    Touché ;)
    I probably have to give in when its time for my next A3 - Well, there are wors ethings than being "lazy", or should we call it comfortable?
    I can wait two more years, if I have to - finally someone will break it. In any case, 150 hp (140 in my current) is usually sufficient for my 70 km daily commuting :) But 180 hp is more fun if course ;)
  17. GreatBallsofFire
    151
    Hmm ;)
  18. arad85
    856
    315
    230+hp is even better :arco:
  19. GreatBallsofFire
    151
    Sure is, congrats :) but mainly on autobahn.;) For me its not crucial..yet. 180 will be fine for me.:) Or even if I have to settle with the original 150. Quattro is more important :) (remember, this is me, and only my views).
  20. arad85
    856
    315
    Personally I enjoy acceleration over maximum speed and it is more useful for overtaking.
  21. GreatBallsofFire
    151
    I certainly would not argue against that. Do you have a tuning box?
  22. arad85
    856
    315
    Yes. A DTUK one. Had it installed for a week and love it so far.
  23. andy203
    andy203 181 BHP
    280
    61
    What effect did it have on your Insurance premium?
  24. arad85
    856
    315
    It is down on my insurance as "Engine management chip - changed" as it was the best compromise we could come to. About +£40/year on ~£400/year fully comp. (I'm part way through the year, so don't have the exact figures for a full year). So a 10% hike. That's for me and my partner driving (50 & 42).
    You may do better/worse if your insurance has a different classification for the box (we're with LV this year).
  25. GreatBallsofFire
    151
    I am considering this one (link below). BSR is a well known trim company and the increase in effects is pretty good. Anyone here has tried it? (2.0 tdi 150 or 184 bhp)
    http://en.bsr.se/tuning-kits/t/2736
  26. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,764
    The JB1 box from Burger Motorsport is also available.
  27. GreatBallsofFire
    151
    Is that a box trim? For the BSR kit you just plug the device into the car and get the engine remapped in an instant. Engine insurance seems to be included. Not cheap tough, but I think I will go for one as soon as I have done my first service (which is next month). Will be nice to have 194 diesel bhp.
  28. GreatBallsofFire
    151
    I am bit surprised, I really would have anticipated a somewhat greater interest for this kind of more elegant trim, which is convenient and can easily be removed to standard when it is time for service. Not anyone has tried it or know someone that has?
  29. thewanted
    thewanted Active Member
    280
    95
    The JB1 only works with the EA888 Gen3 petrol engine.
  30. veeeight
    6,849
    4,764
    Yes, I know that. I didn't see the TDi in the thread title!
