Remap at R-Tech
Sanj May 4, 2011
  1. Sanj
    Sanj Blue Beast
    175
    Hi Guys,
    So I found the time during the 2 long weekends last week to head up to leicester
    and get my remap from R-Tech. The guys got my car on the dyna
    for a run, performed a smoke test and then loaded the remap for a last run.
    I have a few leaks which i need to sort out:
    -N75 valve
    -Injector Seals
    -PCV system (advised to do the catch can mod)
    -Air leak on the B5 tip (i think just needs tightening)
    -N249 bypass delete
    My graph is below, what do you guys think? should i be getting more out
    of my car?
    Not sure its too clear on the picture but the stats are:
    Max Power (Rtech) - 214.763 (247.480) / 5260
    Max Power (Stock) - 178.877 (221.408) / 5935
    Max Torque (Rtech) - 220.29 (248.73) / 4203
    Max Torque (Stock) - 169.38 (197.50) / 3883
    its quite aggresive at 3500-4000 rpm so much so that, foot down
    in 1st gear up to 4000rpm, change to 2nd foot down again, the traction control
    kicks in. I dont always drive aggressive, but not sure this should happen?
    Thoughts appreciated.
  2. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    u will get more power with all the leaks sorted and it should correct ur curve as boost will be ******* out everywhere
    4k in first is quite high in the rpm so its normal mate. just means the boost is coming on. just have to change ur driving style a bit
  3. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    these are my old results
    Pretty similar results to yours
    Power 211 atw (247)
    Torque 224 (247)
  4. Dane
    4,086
    182
    Although the delivery is different, I was still at c. 200 horse power at 6700 rpm
  5. Sanj
    Sanj Blue Beast
    175
    Cheers Dane, are you on 278 through stage 1?
  6. Turboman-a3
    Turboman-a3 speed thrills
    153
    I presume these results for an s3 I thought they where around 200 standard? do they run a ko4?
  7. DaveA3
    2,370
    15
    k04 mate
    210 or 225 as standard. believe its the BAM engine code for 225. May be others however.
  8. Sanj
    Sanj Blue Beast
    175
    ^^^^ What he said.... mines a 225 K04 BAM, but i believe there were 221.
  9. Dane
    4,086
    182
  10. Sanj
    Sanj Blue Beast
    175
    Thats insane, Mine already had the B5 tip fitted and the Jetex Filter, So may have been even lower without it.
    Do you think the figures i have is average?
  11. Dane
    4,086
    182
    The results may very well have been lower however different cars have shown different gains.
    247 bhp and 248ftlbs is about average for a stage 1 map yes, but with any luck sorting out your problems should help bring the figures up.
    Having said that its not all about peak figures, the delivery is important as well, my max torque figure dropped a little but it is delivered constantly for around 3000 revs.
  12. Sanj
    Sanj Blue Beast
    175
    Kool, will work on the leaks, and hopefully get it tested on a dyno locally again.
