#Remap and RR Day @ Chipped UK- Saturday 30th May - £250 with before and Afters#
Discussion in 'Chip 'n' Spin Ecu Tuning' started by Chip-n-spin, Mar 17, 2009.
  1. Chip-n-spin
    Offline
    Chip-n-spin ECU Remap & Tuning Specialists
    Jul 9, 2007
    411
    [Mar 17, 2009]
    Right Guys and Girls,
    Here it is the next Remap and Rolling Road Day.
    When - Saturday 30th May
    Where - Chipped UK, Bromsgrove http://www.chippeduk.com/content/en/Contact_Us.html
    How Much - £250 with Before and After Runs on the rollers.
    £30 for Rolling road power runs only
    We are now able to Map the 1.4tsi, 1.8Tfsi and 143hp 2.0Tdi, but due to costings these may cost slightly more.
    How to book - Email me (sales@chip-n-spin.co.uk) your contact details, car and requirements.
    Feedback from previous days
    http://www.vwaudiforum.co.uk/forum/s...ad.php?t=26756
    http://www.vwaudiforum.co.uk/forum/s...ad.php?t=21905
    http://www.vwaudiforum.co.uk/forum/s...ad.php?t=15709
    http://www.vwaudiforum.co.uk/forum/s...ad.php?t=18829
    http://www.vwaudiforum.co.uk/forum/s...ad.php?t=44168
    #1
  2. Chip-n-spin
    Offline
    Jul 9, 2007
    411
  3. jones_g
    Offline
    jones_g New Member
    Jan 19, 2009
    22
    [Mar 21, 2009]
    Hi mate,
    I came to your last RR/remap day on the 28th of Feb in my Black Audi A4 1.8T, the one that was losing crankcase pressure due to the broken dipstick......
    Can I come along for a dyno run only so I can see what its putting out now I've replaced the dipstick??
  4. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [Mar 22, 2009]
    No problem
    #4
  5. Chip-n-spin
    Offline
    Jul 9, 2007
    411
  6. Chip-n-spin
    Offline
    Jul 9, 2007
    411
  7. BahnStormer77
    Offline
    BahnStormer77 BahnStormer
    Feb 4, 2009
    2,643
    20
    [Apr 12, 2009]
    is the RR at Chipped UK a 4WD ("Quattro friendly" :)) rolling road?
    #7
  8. S3 GEORGE
    Offline
    S3 GEORGE GEORGE
    Jan 20, 2008
    109
    [Apr 14, 2009]
    Hi
    can you map a hybrid k04 turbo from Turbo Dynamics
    MD421 Modified compressor housing inlet, C.N.C re-profiled compressor cover for high flow
    compressor, 2283 Spec “Billet Aluminium” Lightweight Compressor Wheel. modified
    seal plate, 360 degree thrust bearing, K04 Large trim left hand thread turbine wheel with
    lightening of turbine wheel for faster ‘spool up’, C.N.C. modified turbine housing for
    higher flow, up-rated twin turbine seals, 0.8 Bar up-rated actuator. Other ‘blueprinting’
    modifications. APPROX 340-360 BHP Max recommended boost pressure 24-26 PSI.
    how does it sound and what realistic power should i expect im using a tubular manifold and 3 ince downpipe?
    George
    #8
  9. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [Apr 14, 2009]
    Yes it is 4wd.
    Thanks, Mark
    #9
  10. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [Apr 14, 2009]
    This could be done, but due to the amount of modifications I would suggest going for a live map to get the best from this.
    #10
  11. S3 GEORGE
    Offline
    S3 GEORGE GEORGE
    Jan 20, 2008
    109
    [Apr 14, 2009]
    Ok
    have you done this before? what power should i make?
    and what cost?
    #11
  12. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [Apr 15, 2009]
    I'm a mobile tuner, so don't have the facilities to help you with this one. See this kind of setup make 350hp though. As for a price I can't help you out with this. Your best bet is to call Chipped UK and book yourself in for a live map, Paramount Performance might be an easier one as they are only in Slough.
    Cheers, Mark
    #12
  13. ado66
    Offline
    ado66 New Member
    Apr 18, 2009
    29
    [Apr 18, 2009]
    if its anything like the last one it will be fantastic. after waiting 3 hours for a remap on a standard 97 1.8t which was booked in a couple of months before, they came out with the excuse that it was a really rare chip in the ecu which had been deleted! it couldn't have had anything to do with all the cars that turned up in the afternoon which were not booked in but just needed flashing from the diagnostic port could it? no chance, i'm just being cynical obviously.
    it was ok though because they sorted me out with another chip'n'spin mobile dealer, he was the best in the business on old sheds apparently. he soldered the wrong chip in the next day (must be because they are so rare and have been deleted).
    after i said that the car wasn't running right to the mobile tuner and gave him the vag com errors, he came back the next day and told me to bring the old chip with me, because he needed the software from it, to modify it and make it better (yes i know it's all bs). in reality he needed the old chip to solder it back into my ecu, or at best copy the code from my original chip and flash it to a new one, and then solder that in.
    so the short version is that i am £250 down, and the car is exactly the same as when i foolishly thought that going to these clowns might be a good idea.
    #13
  14. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [Apr 20, 2009]
    This is the first I've heard of this! You have not contacted myself about this problem. Firstly he's not one of my dealers, he's a Chipped UK dealer like myself and I know is work is good, secondly it's not the ECU that has been deleted/discontinued it's the Chip the goes insode the ECU. If you'd have contacted muself or Chipped UK we would have sorted this issue out for you. But you didn't and just choose to leave negative commets. Like I said we would have sort you out one way or another if you'd had let me know.
    #14
  15. Nilz
    Offline
    Nilz Defo worth the wait :)
    Apr 9, 2006
    10,612
    575
    [Apr 21, 2009]
    Sounds good...might have a look into this.
    #15
  16. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [Apr 22, 2009]
    Give me a call or drop me and email if you have any questions.
    Thanks, Mark
    #16
  17. A3Tom
    Offline
    A3Tom Smell my finger.
    Mar 3, 2009
    3,514
    12
    [Apr 25, 2009]
    Hi,
    I'm after a remap and interested in what sort of gains I'll get on a 2000 A3 Sport 1.8T (has throttle cable).
    Bromsgrove isnt far from me and the timings right so I'm in if it all sounds OK. Cars stock engine wise apart from a 007 and a green cotton panel filter so it should be 150bhp at the moment.
    Just to confirm...£250 with a run pre-remap and then a run after to see whats what?.
    How will it compare driving it afterwards, is it more mid range grunt etc?
    Tom
    #17
  18. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [Apr 25, 2009]
    Hi Tom.
    Yes it's £250 all in, gains are 45hp and 70nm. You'll have more mid range grunt and more power through out the whole rev range.
    Regards,
    Mark
    #18
  19. ado66
    Offline
    ado66 New Member
    Apr 18, 2009
    29
    [Apr 26, 2009]
    Do you see? This is how they treat you after they have got your hard earned cash, and made a mess of doing the job they reckoned was "no problem". I think this reply to my earlier post sums up perfectly all you will ever need to know about these people.
    #19
  20. A3Tom
    Offline
    Mar 3, 2009
    3,514
    12
    [Apr 26, 2009]
    Excellent, can you book me in for the 30th please?
    Tom
    #20
  21. acprc
    Offline
    acprc Member
    Mar 8, 2009
    65
    [Apr 26, 2009]
    Hi,
    Are you able to do much with the 170ps TDI B7 Avant Quattro? Interested in a re-map but have heard bad things about the DPF and that the re-map wont give you much in gains.
    Any advice?
    Adam
    #21
  22. acprc
    Offline
    acprc Member
    Mar 8, 2009
    65
    [Apr 26, 2009]
    Hi,
    Any advice?
    Adam
    #22
  23. acprc
    Offline
    acprc Member
    Mar 8, 2009
    65
    [Apr 27, 2009]
    Hi,
    Any advice?
    Adam
    #23
  24. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [Apr 28, 2009]
    Hi Adam,
    Generally these are not an issue, gains are around 40hp and 80nm Max as any more the DPF will get blocked.
    Thanks, Mark
    #24
  25. acprc
    Offline
    acprc Member
    Mar 8, 2009
    65
    [Apr 30, 2009]
    Hi Mark,
    Thanks for the reply. I will be giving the re-map a miss as I am looking for a 100% reliable re-map due to the documented DPF problems. Not sure the "generally" comment gives me the piece of mind I am after as it suggests that you do still have issues and I live to far away to be running back and fore.
    Thanks for your time and response.
    Adam
    #25
  26. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [May 1, 2009]
    These are issues everyone can have, it's only ever a problem if there is an existing problem on the car. But that is the same with any remap the 170 is no different in that respect. We've never had a problem mapping one of these cars as long as there are no issues with the DPF etc. It works 100%. If you change your mind let me know.
    Thanks, Mark
    #26
  27. gr066y
    Offline
    gr066y New Member
    Apr 18, 2009
    [May 1, 2009]
    hi mark i have a s3 2000 210bhp amk model and would like to come along to your remap day could you tell me what i could expect as a return.
    thanks greg
    #27
  28. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [May 4, 2009]
    Hi there,
    Gains are +45hp and +70nm.
    Thanks, Mark
    #28
  29. ash_pearce
    Offline
    ash_pearce Member VCDS Map User
    Feb 16, 2009
    322
    [May 8, 2009]
    Sounds interesting, my engine is an AGU 150bhp could you tell me what the boost will increase to? Just doing some research on different chipping companys and how they make the most of the little ko3 fitted to these engines,
    thanks
    #29
  30. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [May 8, 2009]
    Hi Ash,
    Gains on this are upto 45hp and 70nm. What year is the car?
    Thanks, Mark
    #30
  31. ash_pearce
    Offline
    Feb 16, 2009
    322
    [May 8, 2009]
    its a 1997, could you tell me what the actual boost pressure will be please?
    #31
  32. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [May 9, 2009]
    Standard is 8psi and mapped we push the KO3 to 16psi.
    Thanks, Mark
    #32
  33. A3Tom
    Offline
    Mar 3, 2009
    3,514
    12
    [May 9, 2009]
    Cool, is there any need to change the spring in a Forge 007?, currently I think mine has a green spring in it.
    Tom
    #33
  34. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [May 11, 2009]
    The green spring should be fine as we don't boost the KO3 that high, but if you want a stonnger map you may need to go for the yellow spring.
    See how it is to start with and you can always order one if required.
    Thanks, Mark
    #34
  35. A3Tom
    Offline
    Mar 3, 2009
    3,514
    12
    [May 11, 2009]
    Cheers, thought it was worth a check.
    Thanks again
    T
    #35
  36. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [May 12, 2009]
    You're welcome, look forward to seeing you on the 30th.
    #36
  37. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [May 18, 2009]
    Few spaces left if anyone else is interested.
    #37
  38. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [May 26, 2009]
    Couple more spaces left for Saturday, let me know if you're interested.
    Thanks, Mark
    #38
  39. jones_g
    Offline
    jones_g New Member
    Jan 19, 2009
    22
    [May 26, 2009]
    Hi mate,
    my mate is possibly interested if he can pay by card, would that be ok?
    He's got a Mk5 Golf 1.9 TDI, the 105bhp one. What are the gains on these?
  40. Chip-n-spin
    Offline
    Jul 9, 2007
    411
    [May 26, 2009]
    This shouldn;t be a problem.
    Gains are 40hp and 70nm on these.
    #40
