Relentless V3 manifold installation and testing
slappy_dunbar Nov 29, 2012
  1. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    are you talking about over machining the turbine housing?
    The big wheeled k04 currently installed had that on its initial turbine housing. It definitely flowed better top end but suffered hugely on extra lag by , I reckon 750- 1000rpm over the normal clearance I run... While I think it possibly ran better at 7000rpm, EGTs being lower it was a dog at low range, more like a BT turbo, and added insult being the massive gt35 compressor didn't really flow until rpms where high made for a pretty lowesy unit. Now whether running a smaller compressor , more in keeping with the 2283 and extra turbine clearance has any benefit may be worth looking into..
    What I do have about to be tested is the eliminator turbine housing , which has considerably larger a/r on the turbine but the same 40mm inlet, couple with a gt28 turbine and compressor capable of 380bhp, it'll be run on an xs manifold etc etc and it'll be interesting to see if that can produce better figures.
    I'll drop to a pm now as have something you may be interested in!
  2. slappy_dunbar
    slappy_dunbar Let's Do This
    245
    20
    I think the Eliminator housing will just net you a dog x 2. I hate those things. But your learnings with that big compressor wheel are confirmed with what I'm seeing on the smaller F23 wheel. The stock K04 turbine housing is pretty well soaked at 265g/s. But that doesn't mean it's a lost cause. I'm really interested in testing (cheaply-done) modding of that casting.
  3. beachbuggy
    1,931
    201
    What about running a larger turbine wheel?
    Larger wheel , more gas out quicker?
  4. slappy_dunbar
    245
    20
    I think that's an option. But it'll hinder spool. First let's try machining the casting. What did you do with the big-wheel hybrid? Did you port the inlet and volute entry?
  5. beachbuggy
    1,931
    201
    Ported the inlet, ran about 1.5mm clearance on the exducer and ported the shoulder of the inducer, also removed that horrible lip curve on the waste gate/exducer and replaced it with a straight out shield directing waste gate gasses directly into dp. It was pretty radical tbh.
    I've got a larger turbine to be fitted next...
  6. badger5
    9,376
    1,917
    Your MM not working Doug? chirpy chirp chirp?
  7. beachbuggy
    1,931
    201
    Mm?? What's dat?
  8. Dani_B19
    9,057
    338
    Madmax dv im guessing.
  9. v5 tt
    v5 tt Member
    87
    Doug out of interest what compression pistons did you drop in your stroker engine ?
    Edit sorry dont mean to divert thread to much just used Google
    Stock TT pistons ? ( 9.0.1 )
    alterd rod ratio
    Fsi crank
    giving you 1968cc is this right ?
    iv going for
    83mm pistons 9.5.1
    H-beam rods
    fsi crank
    2008cc
  10. slappy_dunbar
    245
    20
    Man, you're resourceful.
    Everything's correct but for the crank spec. It's a Chinese-sourced ALH-engine 95.5 stroke unit. And yes, the car's original pistons stayed with the car.
    Old crank out:
    Pistons out:
    Honing the block in situ:
    Re-ringing the pistons:
    Pistons back in place:
    RS4-profile cams in the head:
    That's it. 1968cc. Cammed. In one day.
  11. v5 tt
    v5 tt Member
    87
    Oh wow thats excellent insight into a different approach to stroke the engine
    excellent work great pics nice work doug !! really impressive !
    :icon_thumright:
  12. badger5
    9,376
    1,917
    95.5 stroke? wowzers...
    not your std pistons? 144x20 rods? eh? kinda sticks out of the block?.. hehe.. 83mm Pistons used? higher pins, the pistone pictured done look to have any valve reliefs for intake?
    how was block clearance doug on crank swing to rods
    what other mods were required for it?
    I remember the timing wheel thing, but was that for a.n.other reason?
  13. v5 tt
    v5 tt Member
    87
    Bill i "think" the con-rod ratio possibly made to match the stroke with the stock pistons
    oil squirters were blocked off..... from what i caught.....
  14. slappy_dunbar
    245
    20
    Non-standard length connecting rods, Bill. Makes for a questionable rod angle ratio, so I've been very deliberate about thoroughly testing before (if ever) releasing this as a product. There's precedent for even more extreme angles, but not in European petrol engines. It's the Americans, playing with their big-block V8s, who have the experience.
  15. badger5
    9,376
    1,917
    they would be clouted off otherwise I guess.
    pin must be higher in piston with a stroke like that.. 95.5mm vs 86.4mm
    interesting approach
  16. slappy_dunbar
    245
    20
    We removed the oil squirters and blocked off the holes. The conrods are rifle-drilled to compensate for the reduced oil flying around.
  17. v5 tt
    v5 tt Member
    87
    I like the thinking outside of the box though very cool all done in situ awesome
  18. badger5
    9,376
    1,917
    hmmm
    remembering factory chose both oil spray + rifle drilling on std motors, to help cool piston crowns
    What pistons are you running Doug? they look like simple dish no valve reliefs.
  19. slappy_dunbar
    245
    20
    Those are the car's original pistons. That's the idea of this design: retain your original pistons and no machine shop work. Simply hone the cylinders and re-ring the stock pistons. And those two procedures are optional, really.
  20. v5 tt
    v5 tt Member
    87
    And custom rod length to suit the stroke of the engine..
  21. badger5
    9,376
    1,917
    cool approach doug.
    you selling this "kit" yet?
  22. slappy_dunbar
    245
    20
    Yup. And that nice phat TDI crank lends the motor tons of added leverage. You can see it here quite clearly. Also, since this is a manifold thread, you can see the top-end benefit of a high-performance manifold. I was wrong about the stock unit. It really hinders performance.
  23. slappy_dunbar
    245
    20
    Soon this will be entering beta testing, which will be limited to trade professionals. But first, Ed at FFE wants to dismantle the bottom end and send the crank to be measured for warpage. We've already flattened a set of rod bearings -- in less than a year of torture-testing -- so I think we can now double-check the crank to see how its holding up.
  24. v5 tt
    v5 tt Member
    87
    Actually from an old thread im sure there was an instance where TSR blocked off oil
    squirters for a stroker application whether it was for a road or track car i really
    cant remember....
    But great idea Doug
  25. slappy_dunbar
    245
    20
    We blocked them off on the FrankenTT test. But I'd imagine they can simply be dropped a few mm with a nipple. That's a better way, and the kind of thing we'll be exploring in beta testing.
